06-05-2014, 09:37 | #212 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | donod d960 successfully unlock with infinity box Chinese Miracle II [RDA module] v 0.06 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU Current CPU is under test support! Make 'FlashRead' before 'Format' or 'Flash Write' operations! CPU_ID : 8806 , rev : 7000 CPU_CN : CoolSand CT , RDA8852 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8806_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Required data found, extracting code Size: 179200 UserCode : 25804 Elapsed: 00:01:20 Done Reconnect Power/Cable! Last edited by bright hlatini; 06-05-2014 at 09:45. |
The Following 2 Users Say Thank You to bright hlatini For This Useful Post: |
06-10-2014, 13:25 | #213 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Mbd m8000 hang when press call button solve by formatting Code: Chinese Miracle II [RDA module] v 0.07 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:10 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
06-10-2014, 13:31 | #214 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Panther Q777+ Code: Card found: S/N 0000:000 Chinese Miracle II [RDA module] v 0.07 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 2244548 Elapsed: 00:00:57 Done Reconnect Power/Cable! |
The Following 2 Users Say Thank You to VIJAY2U2 For This Useful Post: |
06-11-2014, 14:15 | #215 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | G-VILL G308 Code: Card found: S/N :D:D Chinese Miracle II [RDA module] v 0.07 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 25C2 , rev : 3800 FL_CNM : Macronix , MX25U128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Set : 8809 , 01000000 Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 12344321 Elapsed: 00:01:55 Done Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
06-11-2014, 14:16 | #216 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | G-FIVE W5 Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 25C2 , rev : 3700 FL_CNM : Macronix , MX25U64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Set : 880A , 00800000 Use : 880A_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Recalculate Format Range Format User Area ... CSD WR : 81C056FC , 81C05710 CSD DR : A0000000 , A0008000 , A0010000 CSD MB : 00008000 Format Done Elapsed: 00:03:06 Reconnect Power/Cable! |
06-13-2014, 07:16 | #219 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | YESTEL 306 Code: Card found: S/N 0000:0000 Chinese Miracle II [RDA module] v 0.07 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Set : 8809 , 00800000 Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:02:59 Reconnect Power/Cable! |
06-13-2014, 15:22 | #220 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | RichTel A VE-07 Code: Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:01:34 Done Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:15 Reconnect Power/Cable! |
06-14-2014, 12:25 | #221 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 34
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | YESSBOSS E440 TV RDA8851A CPU Read Info Read Code Read Flash Done Code: Chinese Miracle II [RDA module] v 0.07 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Checking step #1, wait ... Checking step #2, wait ... Elapsed: 00:00:22 Done Reconnect Power/Cable! Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:54 Done Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 1425408 bytes read Verify file... Con't collect Project Info , saving as default Saved as : 88094005_00400000.bin Done Elapsed: 00:06:23 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Gsm.Universal For This Useful Post: |
06-21-2014, 13:53 | #222 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Nokia copy Read Info Read Code Read Flash Done |
The Following 2 Users Say Thank You to .::TEJARAM::. For This Useful Post: |
06-23-2014, 16:18 | #223 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2108593 Status: Offline Thanks Meter: 839 | always shows this error Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run InitERR : 00000000 Boot Error , check cable, HW. Check "Docs" folder for more info Reconnect Power/Cable! |
