03-24-2014, 19:16 | #61 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sometimes resolder can help, but chance is very low. |
The Following User Says Thank You to Dzirt For This Useful Post: |
03-24-2014, 19:17 | #62 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | Yes, iīd know it. I have flashes readed from VolcanoBox, i test 1, but is not luck. Also, i have original flash files (lod), but your software donīt recognize. PS: This files are needed for your team? All are lod files, tested on several phones. If yes, i can upload those. |
03-24-2014, 19:21 | #63 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
In fact - CM can make LOD files and support as well , but them not much. About files - will be good - pack them to rar and send us link. We prepare them and upload on support little later. | |
03-25-2014, 05:45 | #65 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | Quote:
hello yewllow man coolsand and RDA can,t be dead during format .i think if he is press keep power button after format more 2 mint .sellphone will be self power on again | |
The Following User Says Thank You to ihsan.khan.gsm For This Useful Post: |
03-25-2014, 05:45 | #66 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Quote:
gfive w5 8851a 8mb - Download - 4shared | |
The Following 2 Users Say Thank You to sultan_ For This Useful Post: |
03-25-2014, 08:30 | #69 (permalink) | ||
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote: Quote:
Thanks! If count of them not bad in hands - I will add that in near version | ||
03-26-2014, 07:59 | #70 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | G...ViLL G-808 RDA8851(16MB)Report CMII v 0.04 READ INFO Code: Chinese Miracle II [RDA module] v 0.04 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:05 Done Reconnect Power/Cable! READ USER CODE Code: Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:01:54 Done Reconnect Power/Cable! Code: Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 356817051852124 IMEI2 : 356817051852132 New Phone IMEI : IMEI1 : 35002587411112-6 IMEI2 : 35002587422223-8 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
03-26-2014, 09:07 | #71 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | G...ViLL G-808 RDA8851(16MB)Report CMII v 0.04 Read FullFlash Code: Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 16777216 bytes read Verify file... Project Info : X22 [BIN] Saved as : X22.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\CSD_X22_.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\CSD_X22_.ifc Build done Done Elapsed: 01:11:56 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-26-2014, 12:04 | #74 (permalink) | |
Thank you ! | |
