09-03-2009, 17:26 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 40
Member: 128753 Status: Offline Sonork: 100.1607515 Thanks Meter: 99 | ChineseMiracle v2.91 can't boot phone, Why ?? ChineseMiracle v2.91 can not boot them: Here is log: COM71 [Serial2] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware R226_PCB01_GPRS_MT6225_S00.R229A_HED_FOR11_V00_04_ 20081125__Nokia-S515_16m_En_Ru_Fr_Es_It_Pl_Ml_Id_Th_Vn_Tr_Farsi_Pt _Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E403:0002 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 15 sec Remove/Install battery now ! and here: COM71 [Serial2] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BF5C:89E6 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 30 sec Remove/Install battery now ! |
09-03-2009, 21:32 | #3 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | a dvice u delete unused port ur pC and give to low port to spiderman after try again.. Today ı test 2.91 with TTN mobile : TTN Mobile OK COM21 [VCP1] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "Register mercury" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:BA03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12. BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 checking psn code area... ............................................... present: psn code area detecting psn code area... ........ found: psn code area flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: psn code area psn code area is fixed detecting psn code area... found: psn code area flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: psn code area psn code area is fixed detecting psn code area... .................................................. .................................................. .................................................. .................................................. ................................................ psn code area is absent or fixed already Finished, time used: 91 sec Remove/Install battery now ! |
09-04-2009, 05:14 | #4 (permalink) |
Member: 128753 Status: Offline Sonork: 100.1607515 Thanks Meter: 99 | When i use oder CMD modules (v2.90) , work ok Infinity team please check this ! What's mater with ChineseMiracle v2.91 ??? here log: COM21 [Serial2] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 9 sec Remove/Install battery now ! ==== log: [9/4/2009 11:10:40 AM] ==== COM21 [Serial2] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0203:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.97CB3218.[LJ11_PCB01_GPRS_MT6225_S00.LE25_ENRUVI_V2_1.BIN_D9 512F6D].rpl ==================== New firmware detected (v.2.90, database date: unknown): LJ11_PCB01_GPRS_MT6225_S00.LE25_ENRUVI_V2_1.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 97CB3218 rom info protocol ver: 04 ver. sw 1: LJ11_PCB01_GPRS_MT6225_S00.LE25_ENRUVI_V2_1.BIN ver. sw 2: LE25_ENRUVI.V2.1, 92D0AE26 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 89880F00010001:89880F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: LJ11_PCB01_GPRS_MT6225_S00.LE25_ENRUVI_V2_1__fullf lash... |
why my box can't boot Trident phone | coolderheart | NSPRO | 0 | 02-20-2010 13:24 |
ChineseMiracle v2.96 can't detect new flash chip | Star75 | Infinity-Box | 4 | 11-22-2009 09:34 |
ChineseMiracle v2.91 can't write full flash please fix | Star75 | Infinity-Box | 8 | 11-08-2009 10:39 |
ChineseMiracle v2.79 Detect New Firmware and can't read phone code | Star75 | Infinity-Box | 8 | 05-30-2009 16:14 |
v3re boot C.F4 can't downgrade - uynlock why? | Formingus | Smart-Clip | 13 | 06-24-2008 09:34 |
