05-29-2018, 01:11 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: Philippines
Member: 764564 Status: Offline Thanks Meter: 7 | CM2 QLM Problem Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! 1. Always device not found ,detected in device manager and AST module ,i'd tried 3 units qualcom chips but allways not found. Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : version:0.5 INFO : variant:MTP eMMC INFO : secure:yes INFO : version-baseband: INFO : version-bootloader: INFO : display-panel: INFO : off-mode-charge:0 INFO : charger-screen-enabled:0 INFO : max-download-size: 0x1ff00000 INFO : partition-type:cache:ext4 INFO : partition-size:cache: 0x10000000 INFO : partition-type:userdata:ext4 INFO : partition-size:userdata: 0x299379e00 INFO : partition-type:system:ext4 INFO : partition-size:system: 0xc0000000 INFO : serialno:6f76ccf2 OEM : Device tampered: false OEM : Device unlocked: false OEM : Device critical unlocked: false OEM : Charger screen enabled: false OEM : Display panel: Done! Elapsed: 00:00:27 what should i do infinity team help.. |
05-29-2018, 09:08 | #5 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
You need to connect phone in EDL mode. Edl mode can be done by either both volume keys or EDL cable or command or Test Point. By the way which driver you see in device manager after you connect phone to pc when trying in EDL mode? Br. Infinity Box Team. | |
05-29-2018, 10:19 | #8 (permalink) | |
06-01-2018, 11:35 | #9 (permalink) | ||
Freak Poster Join Date: Jun 2013 Location: Philippines
Member: 1951934 Status: Offline Thanks Meter: 90 | CM2 QLM Problem Quote:
and download this driver your problem solve | ||
The Following User Says Thank You to bagik For This Useful Post: |
