12-27-2016, 12:59 | #18 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | Quote:
if you extract the file on my previous post you will see 2 drivers, 1 is 'emergencydownload', the other is 'caresuiteconnectivity'... the latter is the one that works when you install it manually. | |
12-27-2016, 13:35 | #19 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
http://forum.gsmhosting.com/vbb/12241628-post45.html | |
The Following 3 Users Say Thank You to rebainoor For This Useful Post: |
12-27-2016, 14:59 | #20 (permalink) | |
the drivers that you shared worked, i've chose the "caresuiteconnectivity" manually instead of "emergencydownload" which they always suggest, and it was a success. thanks to you for that thats why i'm telling infinity support to include the drivers you shared in there support area, specifically the "CareSuiteConnectivy"... Last edited by wohlstand; 12-27-2016 at 15:05. | |
The Following 2 Users Say Thank You to wohlstand For This Useful Post: |
12-27-2016, 15:18 | #21 (permalink) | |
12-27-2016, 15:43 | #22 (permalink) |
Member: 1109337 Status: Offline Thanks Meter: 197 | my point here is that they keep insisting to manually choose 'emergencydownload' to those having trouble replacing 'qualcomm... 9008' which many already said it does not work, including me. no one is suggesting to choose manually 'caresuiteconnectivity' as an alternative to 'emergencydownload'. so to those having trouble replacing 'qualcomm... 9008', just choose 'caresuiteconnectivity' instead of 'emergencydownload'. link to driver is given by rebainoor on his previous post |
01-08-2017, 16:41 | #23 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Thread Update For Those Who Still Have Problem Installing Driver Here Is Another Solution Step By Step First Of All Download These Drivers Or Download From Support https://mega.nz/#F!Z4Q0SQaC!2HUletKfRmMgRBRAzCnbXg LOOK Here Then Install All Drivers One By One After Installing All Drivers Right Click On Qualcomm HS-USB QDLoader 9008 and Select Update Driver Software Click On Browse My Computer For Driver Software Select Let Me Pick from a List of Device Drivers on My Computer Click Next and Scroll Down For Universal Serial Bus Devices Select Universal Serial Bus Devices and Click Next Now Select Care Suite USB Connectivity Click Next It Will Ask For Update Driver Warning Select Yes Wait Until Installation Complete Yes You have Successfully Installed Care Suite USB Connectivity Lets Check With CM2 QLM If You Still Don't Understand Then I think You Should Go Back To College Thanks BEST Regards |
The Following 17 Users Say Thank You to CYB3R GSM For This Useful Post: |
02-25-2017, 09:49 | #24 (permalink) |
Insane Poster Join Date: Sep 2007 Location: yadiki,AP,INDIA
Member: 584794 Status: Offline Thanks Meter: 24 | still drivers problem never sallow.... i will try to upadate qualcomm drivers via manually as ur given process but it has updating QUHSB_BULK never connect emergency mode |
