12-02-2019, 18:07 | #106 (permalink) |
Freak Poster Join Date: Aug 2015 Location: morocco Age: 24
Member: 2444197 Status: Offline Sonork: Y Thanks Meter: 17 | Best dongle problem |
12-04-2019, 15:03 | #110 (permalink) |
Junior Member Join Date: Mar 2015 Location: Sudan
Member: 2365646 Status: Offline Thanks Meter: 10 | I need helep Mu card sn E86E8063 === DongleManager [Infinity] v1.72 [04/12/2019 15:55:58] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102806320281292 === Process started: 04/12/2019 15:55:58 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
12-04-2019, 18:21 | #111 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
12-05-2019, 09:03 | #112 (permalink) |
Junior Member Join Date: Nov 2015 Location: Volgograd
Member: 2488637 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [05.12.2019 11:59:23] === Searching... Card-Reader: FT SCR2000 0 HWID: 01027E7A1C6A1292 Box/Dongle found: [BEST] Serial No (S/N): 09387E7A Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 54 "UK Edition" status: Off Last launched Application: 0030 v.0137 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 - 07: #7 Diagnostic Key: 7F23823DB36AAF55 Last edited by donneo; 12-05-2019 at 09:12. Reason: can't attach file |
12-05-2019, 10:52 | #113 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
12-05-2019, 11:22 | #114 (permalink) | |
Member: 2365646 Status: Offline Thanks Meter: 10 | Quote:
Thank you, Mr The update was successful | |
12-06-2019, 09:56 | #115 (permalink) |
Major Poster Join Date: Dec 2010
Member: 1458352 Status: Offline Thanks Meter: 4 | Hello Mr. Infinity-Box, please help me solve my BEST DONGLE, sympathy for my English (best warning dongle misconfiguration) 1...=== DongleManager [Infinity] v1.72 [12/6/2019 15:49:46] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0008A86220881292 Box/Dongle found: [BEST] Reading... Serial No (S/N): ED04A862 Firmware version: 0122.02 === Process started: 12/6/2019 15:49:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 2..,=== DongleManager [Infinity] v1.72 [12/6/2019 15:34:10] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0008A86220881292 Box/Dongle found: [BEST] Serial No (S/N): ED04A862 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 30 "UK Edition" status: On Last launched Application: 0030 v.0229 => Activations: - 03: [BEST] v.0122 Diagnostic Key: 7FCA123D87833B96 3...,ard-Reader: Alcor Micro USB Smart Card Reader 0 ATR: 3B7D95000080318065B0831148C883009000 Card Manager: A000000018434D00 SerialNumber: 0008A862 ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3173 Serial Number: 0008A862 Batch Identifier: 2088 Module Fabricator: 1292 Module Packaging Date: 4247 IC Card Manufacturer: 2003 IC Em******* Date: 4247 Pre Personalizer: 2004 Pre Personalization Date: 4247 Pre Personalization Equipment Identifier: 00000044 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0008A86220881292 GP Version: 2.1.1 SCP Version: 1, Option: 5 |
12-06-2019, 11:13 | #116 (permalink) | |
- Run DongleManager - https://www.infinity-box.com/support/?r=5 - Update Dongle firmware now IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
12-12-2019, 18:53 | #120 (permalink) |
Insane Poster Join Date: Apr 2010 Location: Nigeria
Member: 1278018 Status: Offline Sonork: 100.1683773 Thanks Meter: 13 | please help me rectify this : === DongleManager [Infinity] v1.72 [12/12/2019 18:51:13] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000008FA18434082 Box/Dongle found: Infinity-Box/Dongle === DongleManager [Infinity] v1.72 [12/12/2019 18:52:53] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000008FA18434082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 561408FA Firmware version: 0138.02 === Process started: 12/12/2019 18:52:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Serial No (S/N): 561408FA Firmware version: 0138.02 Box/Dongle misconfiguration Diagnostic code: 5A "UK Edition" status: Off Last launched Application: 0030 v.0138 => Activations: - 00: Infinity-Box/Dongle v.0138 - 07: #7 Diagnostic Key: 7F9EE9F0DDC9F07A thanks |
