05-31-2020, 09:21 | #301 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box (if you have it) If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist this means it's a hardware problem and you should buy new Dongle. | |
05-31-2020, 09:22 | #302 (permalink) | |
Use CM2MT2 v2.11 or fix your PC as per instruction - https://www.infinity-box.com/news/?r=3999 After that update dongle firmware with DongleManager to fix "misconfiguration" message | |
05-31-2020, 09:35 | #303 (permalink) |
Crazy Poster Join Date: Jan 2017 Location: zimbabwe
Member: 2673715 Status: Offline Thanks Meter: 6 | === DongleManager [Infinity] v1.80 [5/31/2020 10:24:09] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001DDC1FF021982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 0903DDC1 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 03: [BEST] v0122 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM help |
05-31-2020, 13:16 | #304 (permalink) | |
06-01-2020, 06:58 | #305 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 540932 Status: Offline Thanks Meter: 36 | === DongleManager [Infinity] v1.80 [6/1/2020 10:54:56] === Searching... Card-Reader: FT SCR2000 0 HWID: 0003657401171292 Box/Dongle found: [BEST] Serial No (S/N): 117B6574 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 03: [BEST] v0122 - 06: #6 - 07: #7 => Options: - Infinity BEST - Infinity SM - spt fault |
06-01-2020, 09:39 | #306 (permalink) | |
There is a conflict with this app: c:\program files\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe Use CM2MT2 v2.11 or fix your PC as per instruction - https://www.infinity-box.com/news/?r=3999 After that update dongle firmware with DongleManager to fix "misconfiguration" message | |
06-02-2020, 09:07 | #307 (permalink) |
Freak Poster Join Date: Feb 2007 Location: thailand
Member: 451521 Status: Offline Thanks Meter: 317 | DongleManager [Infinity] v1.80 [2/6/2020 15:00:07] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000A0C67CF94082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): C490A0C6 Firmware version: 0143.02 === Process started: 2/6/2020 15:00:09 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 ์not show file fault.bin in C:\InfinityBox\CM2MT2 Plz help me |
06-02-2020, 09:14 | #308 (permalink) |
Member: 451521 Status: Offline Thanks Meter: 317 | === DongleManager [Infinity] v1.80 [6/2/2020 1:11:55] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00000FB90EFE4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): B11C0FB9 Firmware version: 0143.02 === Process started: 6/2/2020 1:11:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 s์ame 2 sn not show file fault.bin in C:\InfinityBox\CM2MT2 Plz help me |
06-02-2020, 10:08 | #309 (permalink) | |
06-02-2020, 10:09 | #310 (permalink) | |
06-03-2020, 11:57 | #311 (permalink) |
Freak Poster Join Date: Nov 2016
Member: 2649950 Status: Offline Thanks Meter: 33 | === DongleManager [Infinity] v1.80 [03.06.2020 13:52:58] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000027B718164082 Box/Dongle found: [BEST] Reading... Serial No (S/N): 860027B7 Firmware version: 0122.02 === Process started: 03.06.2020 13:52:59 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Problem After i tried to install 2.11. Support expired previosli i used 2.09. How to fix? |
06-03-2020, 14:49 | #312 (permalink) | |
06-03-2020, 16:12 | #313 (permalink) | |
Member: 2649950 Status: Offline Thanks Meter: 33 | Quote:
After your post i tried to start 2.09 and it had started. I renamed USB mons in programmfiles. After it installed 2.11 and upgrade dongle firmware - in had dowloaded somthing drom net. 2.11 and other SPD not starting with same Miconfiguraton problem. Did you do somthing on your side after mi first post? What am i doing wrong? I dont have Fault.bin in folder. === DongleManager [Infinity] v1.80 [03.06.2020 18:11:54] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000027B718164082 Box/Dongle found: [BEST] Serial No (S/N): 860027B7 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 03: [BEST] v0122 => Options: - Infinity BEST | |
06-04-2020, 10:43 | #314 (permalink) | |
Let me know when it will be completed, I will tell you what to do then | |
06-04-2020, 11:14 | #315 (permalink) | |
I don't have C:\Program Files (x86)\Intel\Bluetooth\devmonsrv.exe C:\Program Files (x86)\Nec Electronics\usb 3.0 host controller driver\application\nusb3mon.exe i renamed C:\Program Files\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe_ C:\Program Files\Renesas Electronics\usb 3.0 host controller driver\application\nusb3mon.exe_ C:\Program Files\via xhci uasp utility\usb3Monitor.exe_ 2.11 is installed, and not working. DM i didn't start today. | |
