01-02-2016, 19:11 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 455296 Status: Offline Sonork: xxxxxxxxx Thanks Meter: 66 | F1:[MT6572][eMMC] Dead Boot - VSun V3B recived a VSUN MT6572 V3 phone in dead boot; tried some operations but got the following error for every single operation. need some explanation please :-) Code: BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Now, Let's check to see if it has been discussed before: searched the forum and found three result: - PLZ halp HUAWEI-G610-U200 Boot Error -- Huawei G610 Secure Bootloader, not completely Supported at the moment and no answer from support or success from user. - huawei g610-u20 boot error -- no reply at all, never mind, secure bootloader - Help me with Videocon A29F -- after playing alot, eMMC went down; "eMMC_ID : 0600003136FFFFFFFFFF195C493934EB" said JayDi why am I putting this here?! well I have a request from support: Please make a Error Index thread to stop us from spamming the forum :-) and to have a place to look for, before making new thread. (just make a count of posts about Huawei G610-U20 with secured bootloader ) and the full log: Code: Start at : [1/2/2016 / 6:49:44 PM] Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Finish at : [1/2/2016 / 6:49:58 PM] ========================= Start ========================= 1/2/2016 / 7:08:50 PM ========================================================= Card found : S/N : C104968B , v0129 Chinese Miracle II [MTK module] v 1.40 User selected Preloader file : preloader_mbk72_wet_jb3.bin Start at : [1/2/2016 / 7:09:15 PM] Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [4] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:09:28 PM] User selected Preloader file : preloader_mbk72_wet_jb3.bin Start at : [1/2/2016 / 7:09:41 PM] Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [4] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:10:17 PM] Scatter Load Ok , BaseBand : MT6572 , Project : mbk72_wet_jb3 , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Start at : [1/2/2016 / 7:10:34 PM] Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:11:01 PM] User selected Preloader file : preloader_mbk72_wet_jb3.bin Start at : [1/2/2016 / 7:11:10 PM] Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [4] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:11:38 PM] Start at : [1/2/2016 / 7:11:43 PM] Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:11:49 PM] Start at : [1/2/2016 / 7:11:57 PM] Operation : Flash Erase [ v1.40 ] User accepted Flash Erase operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:12:07 PM] User selected Preloader file : preloader_mbk72_wet_jb3.bin Start at : [1/2/2016 / 7:12:22 PM] Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [4] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:12:31 PM] Start at : [1/2/2016 / 7:20:13 PM] Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A4D50E817F DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [1/2/2016 / 7:20:36 PM] |
