12-27-2015, 14:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | PLZ halp HUAWEI-G610-U200 Boot Error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
12-27-2015, 15:01 | #2 (permalink) |
Member: 2166444 Status: Offline Thanks Meter: 298 | SP mode erroe Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v3.2 on BBID : 0x86 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
12-27-2015, 15:07 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | Flash the phone with boot cable (modified cable) with out battery I flash same phone today but tell what's the condition of the phone when come to your hand. |
