04-24-2011, 19:12 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Moro
Member: 918056 Status: Offline Sonork: 1636876 Thanks Meter: 70 | first testing pinfinder failed i try to find a pinfinder adapter pinout alcatel ot701x juste for testing but no success her is screen shot Uploaded with ImageShack.us |
04-24-2011, 19:23 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can you power On phone using pinfinder power? this is main rule for success pinout search. If yes, please repeat search with "finder activation tries" set to 20 |
04-24-2011, 20:09 | #3 (permalink) |
Member: 918056 Status: Offline Sonork: 1636876 Thanks Meter: 70 | same problem i press power on by holding as the search is over! Uploaded with ImageShack.us Uploaded with ImageShack.us |
04-25-2011, 19:56 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, you doing all correctly, when pressing and holding power button. but please test follwoing: start pinfinder software, select cable type and press "power On". after that try to power On phone. can you power it on? |
04-26-2011, 00:19 | #5 (permalink) |
Member: 918056 Status: Offline Sonork: 1636876 Thanks Meter: 70 | yes i power it on! but what happen? ther are two pinfinder box try it by he same problem note:i chuse a pinout correte indicated from the liste then i press set button;in software suport ot 701x phone can't connect ;same problem by other phone connector 2x5 /1 2 3 4 5\ |6 7 8 9 10| 4: %tx% 5: %rx% 6: %gnd% |
04-30-2011, 21:08 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. download and install latest Infinity-Box Shell so you will be able to see detailed rx/tx description instead of %rx% and %tx% text 2. if PinFinder can not find pinout for OT-701 you have to double check that cable inserted into phone connector really well. I have tested 701 phone with PinFinder by myself and it was no problems. |
Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-20-2000 16:39 |
I have that soft if smb need ask for testing.. | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-01-2000 23:47 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
