06-19-2008, 18:43 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Weston-super-Mare, UK Age: 40
Member: 198717 Status: Offline Thanks Meter: 16 | Fly SX200 will not unlock on M-Module 2.24 Action: unlock unlock method: smart fast Model: Fly-SX200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:1903:0005 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.07A.W07.36.MP.V23 Version: EZIO25_07A_HW 44 byte(s) read imei: 35342302015665 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... error: verification failed done Finished, time used: 15 sec Remove/Install battery now ! Any ideas? |
06-19-2008, 19:49 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Good day ! 1. make eeprom backup for emergency case 2. repeat unlock operation if still no luck follow the next instruction step by step: 3. make "format ffs" in "complete" mode 4. power-on phone 5. power-off phone (do NOT remove batery, power-of phone by "power" button) 6. make unlock again 7. repair imei |
06-19-2008, 21:23 | #3 (permalink) |
Member: 198717 Status: Offline Thanks Meter: 16 | Worked a treat.. Thank you. May I also add using Mode-2 for IMEI repair works best |
The Following User Says Thank You to drancill For This Useful Post: |
06-29-2008, 12:29 | #4 (permalink) | |
Registered User Join Date: Dec 2007 Location: fazal Haroonabad Pakistan Age: 46
Member: 650213 Status: Offline Sonork: 100.1581739:333 Thanks Meter: 133 | Quote:
COM5 [Serial2] selected Action: unlock unlock method: smart fast Model: Fly-SX200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:9703:0007 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.07A.W07.36.MP.V23 Version: EZIO25_07A_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is wrong ! It's need to repair imei for correct phone functionality ! connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! best rgrd of team | |
The Following User Says Thank You to gsm5378 For This Useful Post: |
06-29-2008, 12:52 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Fly SX200 dead while Unlock | Nasmi | Infinity-Box | 1 | 01-23-2009 17:00 |
Fly Sx200 Cannot Be unlocked | Amir-SkillZ | Infinity-Box | 3 | 05-25-2008 08:57 |
