06-10-2009, 18:03 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | hauwaei t161l unlock sucessfully module v1.60 Device: Huawei-T161l Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090217-000137.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090217-000138.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090217-000144.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090217-000204.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to nadirghazi For This Useful Post: |
03-10-2010, 05:13 | #2 (permalink) |
Freak Poster Join Date: Jan 2006 Location: peru Age: 57
Member: 215758 Status: Offline Thanks Meter: 33 | Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware it leaves this part to you I believe that in mine so that error does not finalize Seleccionar velocidad Done Connecting ... Flash 8000:8000 Connecting Done Check hardware . |
03-10-2010, 14:30 | #3 (permalink) | |
It may be unknown or damaged (hardware) flash chip. | |
03-11-2010, 04:18 | #4 (permalink) |
Member: 215758 Status: Offline Thanks Meter: 33 | this cellular one I only want to change the ixxi to him and unlock but the machine normal mode power, have to say to me so that it recognizes another flash you go |
04-12-2010, 20:35 | #5 (permalink) |
Freak Poster Join Date: May 2006
Member: 269752 Status: Offline Sonork: 100.1613031 Thanks Meter: 85 | i have this phone and is fully working out of the box see the log COM12 [VCP0] selected module v1.77 Device: Huawei-T161L Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 8000:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... reading additional data... error: can't read lock-area backup critical area Failed Finished, time used: 2 min 28 sec Remove/Install battery now ! |
04-12-2010, 21:53 | #6 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Ecuador/Android
Member: 1001831 Status: Offline Sonork: 100.1594557 Thanks Meter: 1,405 | Quote:
Even the boot is not supported | |
:::Huawei T161L Unlock Done::: | ..::Waqar::.. | Infinity-Box | 5 | 12-20-2009 15:20 |
Jazz T161L unlocked successfuly | murtaza_nns | Infinity-Box | 9 | 02-14-2009 09:05 |
Huawei T161L unlocked successfuly (Jazz Mobilink) | GSM-DOCTOR | Infinity-Box | 9 | 01-21-2009 19:51 |
Huawei T161L unlocked :D | kasrawiz | Infinity-Box | 2 | 01-16-2009 00:06 |
Huawei-T161L unlock suss | tanha | Infinity-Box | 1 | 01-06-2009 19:02 |
