07-10-2008, 14:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL
Member: 119488 Status: Offline Thanks Meter: 24 | help MITO 288GG.. i have this problem, its dual simcard phone, the problem is when insert simcard phone become restart...i try to format & succsess..but imei its different.. the problem is i cant change imei coz i cant see imei on the back of the phone..only name of the phone,barcode,sn... what should i do next??? here a operation log: detect on pinfinder software version: 1.11 cable type: 1x18 (L18A) platform: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:7 Tx:9 time required: 50 sec Power On ! here a backup procedure Device: Autodetect 6205-6227 NOR Done COM5 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:61CC:88BC high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2929C3BD.[E550_A5INDO_E550_GPRS_MT6226_S01.01_3.BIN_1E4CBD46].rpl identification#1 detection finished device-id: 2929C3BD identification#1 protocol ver: 04 ver. sw1: E550_A5INDO_E550_GPRS_MT6226_S01.01_3.BIN ver. sw2: E550_A5INDO.01.3, B942B3E1 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[E550_A5INDO_E550_GPRS_MT6226_S01.01_3.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\mito 288gg E550_A5INDO_E550_GPRS_MT6226_S01.01_3.BIN]_20080709-190351.B0M file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_2929C3 BD_E550_A5INDO_E550_GPRS_MT6226_S01.01_3.BIN_1E4CB D46_20080709-190531.B0X.bin Finished, time used: 693 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP2] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:61CC:88BC Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E550_A5INDO.01.3_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is wrong ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 209 warning: wrong packet cs warning: wrong packet cs 154 of 209 items cleared 0 items remains Finished, time used: 287 sec Remove/Install battery now ! |
11-25-2008, 05:06 | #4 (permalink) |
Junior Member Join Date: Jan 2008
Member: 683826 Status: Offline Thanks Meter: 8 | Hi, i have same phone problem. It was formated, but the phone still restart when i put simcard inside. Here is the log: COM8 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot enabled boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #01 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #02 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #03 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #04 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #05 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #06 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #07 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #08 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #09 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #0A in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #0B in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #0C in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #0D in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #0E in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb detecting chip #0F in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 flash: SST U 2Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00200000 detect device identification#1... detection phase #1... . detection phase #2... ...... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw 1: E550AGENT_S5_E550_GSM_MT6205B_DN.01_6.BIN ver. sw 2: E550AGENT_S5.01.6, 00000000 ffs offset/size: 00190000/00070000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00190000 flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 checking area [00000000]: 00000000-001FFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00190000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00070000 ffs chip: 00 eeprom/ffs area: 00000000:00190000-001FFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: BF734BFFFF0052:90FFFF00000000 flash: BF734BFFFF0052:90FFFF00000000 Finalization Done Finished, time used: 45 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! I cant flash back eeprom/ffs from backup. Should i download firmware from support area and full flash the phone? |
11-25-2008, 18:53 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello mr. adezizu! no, you dont need to flash this phone part. You working with 6205 MCU which is Second (slave) MCU in this phone. Restart ussually caused by software problem in First (master) MCU part. please find first MCU pinout and format it |
Please help with this Phone Mito 288GG | lie_james | Infinity-Box | 15 | 09-17-2009 21:07 |
Help Me.... Mito 288gg screen LCD becomes overturn | frank_pacific_o | SpiderMan | 0 | 07-06-2009 11:28 |
Help Me.... Mito 288gg screen LCD becomes overturn | frank_pacific_o | SpiderMan | 0 | 07-06-2009 11:27 |
mito 288gg | deni cell | Infinity-Box | 1 | 06-16-2008 08:27 |
help - MITO 288GG - eeprom damage | vi element | Infinity-Box | 5 | 12-11-2007 05:19 |
