help pin finder cant activate pls help my i have a problem with my infinity box pin finder i cant activate.. i follow the instruction but still.. if i run the firmware...PLS DOWNLOAD LATEST UPGRADE-CLIENT FROM SUPPORT AREA AND UPGRADE DONGLE FIRMWARE.... then i run donle manager...this is the logs.. ----------Process started:1:30:44 PM---------- Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: xxxx, Firmware: 010F.02 Authenticating on server... Authentication successfull. Checking DongleManager version... Your DongleManager is up-to-date. Checking Dongle Identification... Identification check error: Server reported error:[0034] Dongle and database data mismatch, errorcode #02. Contact to [email protected] any other solution? pls help.. i buy this 2nd hand and i dont have contact with him.. |
Hello, If you will post your dongle S/N again in public forum we will block your dongle for 2 weeks, so pls think next time before post. What to do in your situation: if your PinFinder already was activated DO NOT make PinFinder activation again during box upgrade. |
Did u use Update dongle manager? If not plz download from support area then try to maintain procedure.. Which is already given by infininty main exe (Documentaion tab) |
still not activate tanx 4 fast reply, sorry 4 my 1st post. i follow carefully the instruction but still not working. the version of dongle manager is 1.25 and the pin finder firmware is 1.14.. if this cant be activated again how can i use my pin finder box. i hope have solution 4 this... pls help tanx |
Hello, Try to upgrade dongle one more time. In case of any problems follow instruction given by DongleManager: send problem description and log text to [email protected] |
