06-13-2008, 01:06 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Argentina Age: 69
Member: 91019 Status: Offline Thanks Meter: 62 | Hi Everybody!!!! Thank You very much!!!! |
06-13-2008, 15:44 | #3 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | Yes ... I tried to change imei with infinity-box the software tell me that the change was sucsessfull but i see the imei on phone and it shows the same ... Very Strange problem Can you Help me ? Thank You very much !!! |
06-13-2008, 17:48 | #5 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | Here is the log friend COM40 [VCP0] selected Device: Pantech PG-1410 Checking data, wait... Action: imei repair Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\PNModule\backup__eeprom_Pante ch PG-1410_20080613-134744.8FE.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 16 sec Remove/Install battery now ! After this the phone shows Original imei |
06-13-2008, 20:04 | #7 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | Exactily the same I have bloqued in the program the first numbers of the imei, also y changed the last 5 numbers but the same imei on phone, the imei on phone starts by 0106 i´m trying reseting all, if you have other suggestions please tell me Thank You !!!!! |
06-13-2008, 20:18 | #8 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | i reseted the phone now the imei phone shows 010676000010000 but the phone don`t make calls i think this imei is back listed, but i try to change it again and after this the imei it`s the same I don`t now what to do Thank You for the help ! |
06-14-2008, 16:48 | #10 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | Yes But... The Soft changed the imei to the phone but i tried write imei to other phone and it wrote again the same imei no the imei that i wrote on the soft... The imei that the 2 phones show is this 010676000010000 |
06-18-2008, 16:17 | #14 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | Well i explain all I have phones pantech pg-1410 from Argentina All this phones imei starts by 01091500******* When i try to change imei the software say to my that the imei was changed with the imei that i wrote on the soft like this 35734400******* but when i see the phone´s imei it shows 010676000010000 and this imei is backlisted, i tried with 5 phones and in all happen the same thing .... Here is other log : COM40 [VCP0] selected Device: Pantech PG-1410 Checking data, wait... Action: imei repair Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\PNModule\backup__eeprom_Pante ch PG-1410_20080618-121436.8FE.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 26 sec Remove/Install battery now ! Thanks ! |
hi everybody i need flash for my 6610 | salahsalem | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-23-2003 19:08 |
hi everybody GsM TechnologY good sellers or cheaters thanks??? | CHATAR | The Market Feed Back | 18 | 06-21-2002 12:58 |
Hi EveryBody ! Where i can download C30 fullflash 2.2.0. or 2.0.0 etc...? Please He | mobydick | NON Siemens Brand (ODM Phones) | 2 | 11-28-2001 23:50 |
Hi everybody volkan gsm say my company cheater please write here who i cheater? | XzZ | Trash | 0 | 04-21-2001 19:05 |
