03-03-2009, 10:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: SPAIN-----UK
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | S621X Unlock module v2.58 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:1D03:A00A boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.20345 CC7.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: 20345CC7 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002100048 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_20345CC7_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090303-140830.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_20345CC7_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090303-141041.B0X.bin Finished, time used: 165 sec Remove/Install battery now ! Thx infinity Team........................ |
The Following User Says Thank You to Allunlockingsource For This Useful Post: |
03-03-2009, 10:32 | #2 (permalink) |
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | Another unlock thx infinity team COM5 [VCP0] selected module v2.58 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2703:A00E boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.7973E FE9.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: 7973EFE9 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002050783 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_7973EFE9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090303-142903.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_7973EFE9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090303-143048.B0X.bin Finished, time used: 140 sec Remove/Install battery now ! |
03-03-2009, 17:14 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
.::Alcatel S621x unlocking problim::. | sky_force71 | Infinity-Box | 9 | 08-26-2014 08:54 |
alcatel s621x unlock successful | mustafegur1 | Infinity-Box | 10 | 09-14-2011 16:02 |
thanx infinity lobster alca s621x unlocked | david laborator | Infinity-Box | 7 | 03-09-2009 19:43 |
Alcatel S621X unlock | scebic | Infinity-Box | 6 | 02-04-2009 20:46 |
Alcatel s621x unlock sucessfully full method here | c_ahmad79 | Infinity-Box | 2 | 02-01-2009 14:13 |
