01-15-2009, 18:11 | #1 (permalink) | ||
Junior Member Join Date: Dec 2008
Member: 932976 Status: Offline Thanks Meter: 2 | .::Alcatel S621x unlocking problim::. flash with sim free files.. Quote:
i tray to format ffs but this eror Quote:
afert formating i tray this flash S621X-2ATBHR1_XD54CS03_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-07-22_En_Srpski_De_Hr_Slovencina.B0M S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M S621X-2AVRGB1_XD54CW08_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-08-06_En_Fr_Es_It_De_Virgin.B0M infrinity team plz solaved my problim.. thx... | ||
01-15-2009, 23:06 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. charge battery with external power supply 2. try to make "format" again If you will see error at the same address it may be that phone hardware is damaged (f.e. damaged or bad soldered flash chip). |
01-18-2009, 09:49 | #3 (permalink) | ||
Member: 932976 Status: Offline Thanks Meter: 2 | Quote:
same eror Quote:
not flash chip damige becous set 100% oka 1st time i count with infrinity and flash not tray to any other tool . same problim other member check this thread its counfrm softwear problim i reqest to infrinity teem uplod other flashes s621x on support.....and kindly help me... | ||
01-18-2009, 15:03 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you will see error at the same address it may be that phone hardware is damaged (f.e. damaged or bad soldered flash chip). |
02-10-2009, 09:09 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | hi all nd infinity supporter plz dnt mind i flashed fone with infinity box a lot after some time dats gone dead same customer got 2 fone 1x s621x nd 1x c701x i flashed s621x with infinity box simfree flashing after a few days the fone is in my hand in dead condition the second 1 i unlocked using EU easy unlocker code reader the fone is working good i think simfree file is to big for fone when we flash fone with this flashing its demadge the flash chip neway i know infinity team is good and hard working team plz give a saloution for s621 and s520 every time fone flasing ok error in formating br yasermalik |
02-10-2009, 23:04 | #6 (permalink) | |
Please, read more about flash chip f.e. at http://wikipedia.org to avoid this kind of ideas in future. What is the problem exactly ? | |
02-11-2009, 13:18 | #7 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | the fone was dead flashing complete successfully error in formate safe mode nd formate in complete mode was working ok no power on after flash nd formate i pressed power on button long time but same infinity team u can chack my post i done more then 10 fone using simfree flashing at the end of d day the fone is alive in my hand simply i repaired security area here is log COM4 [VCP0] selected module v2.62 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:6B03:A009 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.8C470 4E0.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: 8C4704E0 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002051385 flash: 01227E22422200:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_8C4704E0_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090211-030813.B0X.bin Finished, time used: 97 sec Remove/Install battery now ! thanks infinity team br yasermalik |
The Following 3 Users Say Thank You to yasermalik For This Useful Post: |
08-26-2014, 08:50 | #8 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 304342 Status: Offline Thanks Meter: 20 | ALCATEL UNLOCK S621 TESTED COM16 [VCP0] selected module v2.79 Action: reset settings Model: Alcatel-S621X, S621A Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3E03:A00B status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.06B.W07.28.SP1.V34 Version: JRD25_06B_HW 44 byte(s) read imei: 35608602000079 connection Ok warning: wrong packet cs building list... done items to clear: 219 warning: wrong packet cs warning: wrong packet cs items cleared: 217 of 219 building list... done items remains: 2 Finished, time used: 37 sec Remove/Install battery now ! |
The Following User Says Thank You to AFZALHASMI For This Useful Post: |
08-26-2014, 08:53 | #9 (permalink) |
Member: 304342 Status: Offline Thanks Meter: 20 | COM16 [VCP0] selected module v2.79 Action: reset settings Model: Alcatel-S621X, S621A Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3E03:A00B status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.06B.W07.28.SP1.V34 Version: JRD25_06B_HW 44 byte(s) read imei: 35608602000079 connection Ok warning: wrong packet cs building list... done items to clear: 219 warning: wrong packet cs warning: wrong packet cs items cleared: 217 of 219 building list... done items remains: 2 Finished, time used: 37 sec Remove/Install battery now ! |
alcatel s621x unlock successful | mustafegur1 | Infinity-Box | 10 | 09-14-2011 16:02 |
thanx infinity lobster alca s621x unlocked | david laborator | Infinity-Box | 7 | 03-09-2009 19:43 |
Alcatel s621x unlock sucessfully full method here | c_ahmad79 | Infinity-Box | 2 | 02-01-2009 14:13 |
..::Alcatel c552x unlock???::.. | afra.com | Alcatel TCL Phones and New Models | 23 | 03-08-2007 07:07 |
