Old 11-29-2008, 01:19   #1 (permalink)
Member: 572230
Thanks Meter: 5
How to Change Language??
Newbie here.
I have searched many posts and still be clueless.
Infinity-box is very different than other box.
Anyway, I have a LG KE970 and want to add Chinese language support.
What I usually did is simply flash a Chinese KE970 firmware.
The problem is I am not which firmware in support area has Chinese.
So I just tried one by one, then the phone can't power on after I flash it.
I revived the phone by some free gsm flash tool.
But I really want to know how to use infinity-box, after all, I paid $200 something for it.
I read some post discuss the language pack editor that is really cool tool.
Then when I try to open it, it ask for higher activation level.
Hum.... so I can't change language unless I pay more? Or, I just doing the wrong way?
Somebody please kindly guide me. Any link, post or a instruction will be appreciate. I did read the documentations, but that confuse me more, since there are too many models list over there.
Also, I am glad to see that Infinity support cect a008, but I cant find a flash file in support area.
My question is:
How to correctly flash KE970
How to change Language into chinese for KE970
How to change Language into chinese for Cect a008
Thank you all
Old 11-29-2008, 01:46   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
I think you have started from wrong point. I suggest you to start your search from your own HDD: C:\Program Files\InfinityBox\Documentation
Answer #1:
How to write flash (step-by-step instruction):
1. connect cable
2. run "Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to unlock (step-by-step instruction):
1. connect cable
7. go to software "Service" page
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (step-by-step instruction):
1. connect cable
8. press "Reset" or "Format" button and follow instruction given by software
Answer #2:
Flash phone with firmware with Chinese language.
You can see files description in support area: \flashfiles\LG\Language_pack_description.txt
But as I can remember there is no files with Chinese language in support area, so here is an instruction what to do:
C:\Program Files\InfinityBox\Documentation\FAQ\How_to_get_latest_flash_files_and_new_languag es.txt
Answer #3:
You can get more information about software here: http://www.infinity-box.biz/index.php?id=langedit&lg=en
You can check current status of Infinity-Box Language Pack Editor software tests here:
http://forum.gsmhosting.com/vbb/showthread.php?t=475453
http://forum.gsmhosting.com/vbb/showthread.php?t=483338
If you have found that this software cover all your requirements and if you are ready to buy copy of Infinity-Box Language Pack Editor
you are welcome to contact to nearest reseller from the next lists:
http://www.infinity-box.biz/index.php?id=howtobuy
http://www.infinity-box.com/dealers.php
You can contact to our sales person directly via e-mail:
[email protected] or [email protected] or by ICQ: 21260138
Do not hesitate to contact us if you will have more questions.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 12-22-2008, 01:46   #3 (permalink)
Member: 572230
Thanks Meter: 5
Thanks for the reply.
I finally found a Chinese KE970 and read out the firmware.
But the size is more than 20MB which can't be accepted by Gmail.
Is there a another way to send you guys the firmware?
thank you.
Old 12-22-2008, 08:55   #4 (permalink)
Member: 130995
Hello,
http://rapidshare.com
Old 12-22-2008, 22:14   #5 (permalink)
Member: 572230
Thanks Meter: 5
Uploaded and send the link to inifinityboxsupport.
Thank you
Old 12-23-2008, 18:14   #6 (permalink)
Member: 130995
Hello,
File downloaded, we will prepare and upload flash files into support area ASAP.
Old 12-30-2008, 02:27   #7 (permalink)
Member: 572230
Thanks Meter: 5
Download KE970P40_ESA-V10g_000-00.B1M.bin from support site.
Flash log:
COM35 [VCP0] selected
Device: LG-KE970
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0089:88B0
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
backup critical area Done
Check memory...
Check memory Done
Write...
reset...
done
Writing: Firmware
Verifying...
Done
Write Done
Finished, Remove/Install battery now !
Time used: 1214 sec
After flash language remain same
check firmware with read information:
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Read info...
software version: KE970P40FL-44-V10c-234-30 APR 27 2007+1
imei: 354xxxxxxxxxxxx
Done
Finished
the software version still v10c
Should I flash FFS-2/File system or eeprom also?
Where can I find the FFS-2 flash file?
Which part I did wrong?
I just want Chinese in KE970
Old 12-30-2008, 10:35   #8 (permalink)
Member: 130995
Hello,
It is no need to write FFS.
We will try to check ASAP what can be wrong.
Old 12-30-2008, 22:20   #9 (permalink)
Member: 572230
Thanks Meter: 5
Please post the solution. Thank you.
Old 03-01-2009, 21:18   #10 (permalink)
Member: 572230
Thanks Meter: 5
so, no solution yet?
Old 03-01-2009, 22:14   #11 (permalink)
Member: 130995
Hello,
Are you sure that you have read flash backup from phone that had Chinese language ?
What languages was in your phone before flash ?
What languages you can see in phone after flash ?
What was original phone firmware version ?
Old 03-03-2009, 04:33   #12 (permalink)
Member: 572230
Thanks Meter: 5
Yeah, I follow the procedure in documation.
The phone has english and other non-chinese language,
(Sorry, it has been a while, kinda forget what language exactly)
After flash, everything stay the same.
Check firmware version remain unchanged.
So the original firmware was KE970P40FL-44-V10c-234-30
Thank you for the help
Old 03-03-2009, 05:41   #13 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Dear infinity box team can we add in china phone urdu Language??
Old 03-03-2009, 16:50   #14 (permalink)
Member: 130995
Hello,
You can flash phone with firmware with Urdu language or you can try to add new language in firmware by yourself.
http:///vbb/showthread.php?t=475453
http:///vbb/showthread.php?t=483338
Old 03-03-2009, 17:05   #15 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Dear team can you tell me how can we finde firmware urdu?
How to change language to English in U8138 tical LG 5 07-26-2005 18:32
how to change language to t100 Legionaru Sony Ericsson 1 08-25-2004 14:47
how to change language to English... masterross VLSI, Conexant, Skyworks and Old Models 6 06-28-2004 11:30
How to change language to c28 v61 iko x1x to x45/x50 2 07-01-2003 18:34
How to change language to C28v61!!! starpho x1x to x45/x50 5 08-10-2001 20:31
Page generated in 0.21016 seconds with 9 queries
