07-09-2018, 10:36 | #856 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,928 | Quote:
Right ? | |
07-16-2018, 19:52 | #857 (permalink) |
Junior Member Join Date: Jan 2008
Member: 673565 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [16/07/2018 15:49:32] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000D75600001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 74FED756 Firmware version: 0136.02 === Process started: 16/07/2018 15:49:36 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 ====================================== please help-me support. |
07-17-2018, 14:48 | #858 (permalink) | |
05-28-2020, 08:28 | #859 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2633463 Status: Offline Thanks Meter: 0 | my cm2 is not working now after update plss help me ==== [5/28/2020 13:40:07] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.80 [5/28/2020 13:40:11] === Searching... Card-Reader: USB CCID Smart Card Reader 0 HWID: 0000FE3B7CEC4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D9AEFE3B Firmware version: 0139.02 === Process started: 5/28/2020 13:40:12 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing check error: Server answer:[0002] Client/Server protocol packet length is invalid. |
05-28-2020, 12:11 | #860 (permalink) | |
Update it once again now. | |
07-20-2020, 12:16 | #861 (permalink) | |
Junior Member Join Date: Aug 2016 Location: Uganda
Member: 2605826 Status: Offline Thanks Meter: 4 | Quote:
Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000137157F634082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): F9163715 Firmware version: 0139.02 Box/Dongle misconfiguration Diagnostic code: 62 "UK Edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v0139 Diagnostic Key: 7FED8627A636A0BF => Options: - Infinity-Box/Dongle | |
07-20-2020, 14:06 | #862 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
09-27-2020, 16:42 | #863 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | == DongleManager [Infinity] v1.80 [2020/09/27 19:07:52] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0202747024881292 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): D5477470 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
09-27-2020, 16:55 | #864 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Read NOTE here - https://www.infinity-box.com/support/?s=2 Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. Next steps: - Delete fault.bin file from software folder (if you have it there) - Run DongleManager - Update Dongle firmware | |
04-05-2021, 16:43 | #865 (permalink) |
Junior Member Join Date: Nov 2017 Location: pakistan
Member: 2776503 Status: Offline Sonork: Thanks Meter: 1 | me also facing....... plz solve sir this issue cm2 all users in trouble plz === DongleManager [Infinity] v1.80 [4/5/2021 20:41:04] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000BCEA7F634082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): DDA5BCEA Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0032 v.0147 => Activations: - 00: Infinity-Box/Dongle v0147 => Options: - Infinity-Box/Dongle |
04-05-2021, 18:27 | #866 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
04-06-2021, 10:01 | #868 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,928 | Hello, 1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe |
12-22-2022, 19:58 | #869 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2242439 Status: Offline Thanks Meter: 6 | Hello Brother i need help about Dongle identification data damaged. === DongleManager [Infinity] v1.92 [12/22/2022 10:53:49 AM] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 000020F621F34082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 37D920F6 Firmware version: 0153.02 === Started: 12/22/2022 10:53:50 AM === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Do you want to report an issue to Support? |
12-23-2022, 02:24 | #870 (permalink) | |
Use FREE repair https://infinity-box.com/?r=100203 | |
