08-01-2008, 11:26 | #152 (permalink) | |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Quote:
Just Check with Multimeter, Pin 2 of RJ connector Should be connected to Device Rx Pin 3 of RJ connector Should be connected to Device Tx Pin 7 & 8 are ground. Regards Shubhanshu | |
08-01-2008, 13:55 | #154 (permalink) | |
Wires should be soldered to phone test-points. Select 24 pin cable in PinFinder and make pinout detection | |
08-01-2008, 22:17 | #155 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | Quote:
That is, I can solder any three wire to phone pcb and can find pinout selecting 24 pin cable. Am I right ? Or any two wire will do ? though ground is already connected.......... | |
08-12-2008, 09:05 | #158 (permalink) |
No Life Poster Join Date: Oct 2007 Location: in your hert
Member: 618615 Status: Offline Thanks Meter: 85 | infinity team plz help i buy new infinity box and pin fider when i use pinfinder open a message update dongle for pinfider when i update pinfider messege show pinfinder not detected pinfider,s rd light is on |
08-12-2008, 09:16 | #159 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
08-13-2008, 12:55 | #160 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | Quote:
and then you must upgrade ure pinfinder How to install Infinity box manual and how to install pinfinder manual both can be downloaded from HERE | |
08-17-2008, 04:44 | #161 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: TO SERVE AND PROTECT
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | Quote:
08-17-2008, 14:10 | #162 (permalink) | |
1. run Infinity-Box Shell 2. select required model 3. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
08-18-2008, 05:30 | #165 (permalink) | |
How to use SpiderMan for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc. | hamada33r | SpiderMan | 13 | 11-16-2008 16:04 |
how to use pinfinder for china | rajendrakumar | Infinity-Box | 1 | 10-02-2008 21:23 |
UNLOCK MY150x: How to use PinFinder with Sagem and other models | alamgarh | Infinity-Box | 22 | 07-13-2008 13:57 |
How to use pinfinder with Pantech PG-C3B | -luigi- | Infinity-Box | 5 | 05-23-2008 02:49 |
How to use patch for DB2020 SE phones? | vetas | Universalbox | 6 | 03-25-2008 14:28 |
