Old 03-08-2009, 22:27   #1 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
how to work with 1:1 copy of apple iphone?
i have one of these:
http://www.diytrade.com/china/4/prod...tml#normal_img
http://www.tech-epoch.com/sdp/827994...6-1738000.html
all is like original even conector.chargue with original usb but i tunes dont identify.
have some little differences like sim case in original are prsent and in these sim input dicerctly and the reset buttom in side of phone.sw aparence too is like all chinesse phones.
problem is have not signal and cant work with pind finder becouse dont have that conector.
Old 03-08-2009, 23:23   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 03-09-2009, 18:48   #3 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
hello!
yes is ok.phone say set to english.but what about the conector?
pind finder dont hat that.
Old 03-10-2009, 11:18   #4 (permalink)
Member: 148515
hello!
if phone can be powered from pinfinder power- we can assume that pinfinder failed to find pinout because there is no Tx/Rx in system connector.
now you must look for test points on PCB. for this you might be need to disassemble phone
Old 03-10-2009, 16:25   #5 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
no,no,no, i mean these iphone use same conector like original and pin finder dont have any cable like that.then maybe you will need a cable for next productions becouse will be more common.
i think for now only way is try to find the signals using a original usb cable and making the own rj45 cable.(huff .is a lot of work)
if some body have any data about i will be glad.
Old 03-11-2009, 21:52   #6 (permalink)
Member: 148515
hello!
analysing USB cable will not give any result.
better to measure voltages on phone pins and detect Tx/rx by voltage 2,7-2,9 volts.
full charged battery must be attached when you do measurments
Old 03-12-2009, 02:13   #7 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
fisrt i need to know if phone have it a 1900 band,but enginering codes dont work.
E71i DEAD TO HELP WITH TRYING TO REPAIR WITH FULL COPY OF FLASH tecnicelltech Infinity-Box 5 08-01-2009 04:53
manual plz to how to work with binfinder usb` melgsm SpiderMan 2 06-22-2008 10:36
How to work with Full flash in Samsung phones ! GSM SNIPER UFS2 + UFS3-Tornadoflasher 3 01-30-2005 08:20
How to work with the terminator Step by step !! GSM SNIPER Sony Ericsson 3 05-30-2004 11:54
How to work with autocal progs for Samsung - help need!!! Sonia VLSI, Conexant, Skyworks and Old Models 1 11-10-2002 03:00
Page generated in 0.17957 seconds with 9 queries
