04-11-2016, 05:34 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MTK Repartition Tool in Action :) MT6735 inside. Do repart : Code: Operation : Repart User Memory [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4E0301886472614307D73520DB186008 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642035D707086062DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x000000039D000000 [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB] DEV RID : 77BAF3D8CA16F13477817A5B13DE95A2 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Available Internal Memory : 12,91 GiB Memory settings detected , waiting user decision Memory size set, initialize new settings Init passed! Power On phone to accept changes! Done! Elapsed: 00:00:57 Reconnect Power/Cable! |
The Following 20 Users Say Thank You to JayDi For This Useful Post: |
04-11-2016, 06:16 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | CM2 Release - http://forum.gsmhosting.com/vbb/f296...tures-2076630/ |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
04-11-2016, 07:16 | #6 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | Card found : S/N : 624xxxxxx , v0130 Chinese Miracle II [MTK module] v 1.45 Operation : Remove Viruses [SmartAV] [ v1.45 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D533237F2F6004279B3CFFE Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200F6F2FECF7279 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 57CD36739B4878DC200F1709117206B3 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 3 Removing infected files and scripts ... SmartAV Report : Removed 3 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Format FileSystem [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D533237F2F6004279B3CFFE Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200F6F2FECF7279 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 57CD36739B4878DC200F1709117206B3 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! thanks team |
04-11-2016, 09:22 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | same error on two phone Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D4202C8159B5223F7 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM72J [eMMC] : FLASH_CID : 150100464A32374D4202C8159B5223F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : E1266E8E702D399ED04C4FE689A6400F INT RAM : 0x00020000 EXT RAM : 0x30000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! That device not have free internal memory for repartition! |
04-11-2016, 09:29 | #11 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
For 4GiB emmc there is : 0.7-1.2 GiB memory for OS. 0.2-0.4 GiB memory for supplementary files 0.1-0.2 GiB for BMT. 0.3-0.4 GiB for Cache There is left normally 1.5-1.7 GiB , which are parted to User memory. Space for internal storage not left. That is why SW say - not have free internal memory. SW not take space from air, it just remap current eMMC space for extend partition. In limited space , when somewhere need increase part - in other place need decrease On 8,16,32,64 GiB there is enough memory for such things. On older platforms can be divide even in 4GiB eMMC's, they support will follow. | |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
04-11-2016, 09:45 | #12 (permalink) | |
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | hy Drit..... mtk 6572 not supot??? Quote:
04-11-2016, 09:47 | #13 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Not supported , why you are confused *Supported models: *All phones, based on MT6582(new), MT6595, MT6735, MT6752, MT6753, MT6795, MT8163, MT8735, MT8783 *and all is emmc , Team will support the models one by one ,be patient This is first tool who did this, Sent from my HTC One X using Tapatalk Last edited by helpo; 04-11-2016 at 09:53. Reason: *Supported models: |
The Following 3 Users Say Thank You to helpo For This Useful Post: |
04-11-2016, 12:04 | #14 (permalink) |
No Life Poster Join Date: Jul 2002 Location: sri lanka Age: 39
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | hi JayDi.., is it possible to fix "encryption unsuccessful" error via re partitioning..! coz some of MTK based phones cannot be fixed by factory reset. |
The Following User Says Thank You to iqballk For This Useful Post: |
04-12-2016, 06:05 | #15 (permalink) | |
For Fix Encryption there is 2 ways : Repair ExtData and Format FS ( mode 2 in FMT ) If both options not help - time to change eMMC. | |
