08-16-2008, 18:12 | #1 (permalink) |
No Life Poster Join Date: May 2006 Age: 18
Member: 269198 Status: Offline Thanks Meter: 78 | huawei t158 unlock success and thanks infinity Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.51 S/N: Wait... Current model: Huawei-T158 Ready COM3 [VCP0] selected Device: Huawei-T158 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Documents and Settings\Administrator\Desktop\Huawei-T158_eeprom-sta_20080816-210541.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Documents and Settings\Administrator\Desktop\Huawei-T158_eeprom-sec_20080816-210544.B1E.bin reading [eeprom-complete]... file saved: C:\Documents and Settings\Administrator\Desktop\Huawei-T158_eeprom-complete_20080816-210552.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 42 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following 2 Users Say Thank You to Satyam321 For This Useful Post: |
08-17-2008, 13:29 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
12-26-2008, 12:40 | #6 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
12-26-2008, 12:52 | #7 (permalink) |
Freak Poster Join Date: Jul 2004 Location: JATT LABLE Age: 43
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | @InfinitySupport Thank you. for replying please what pack of the software do i down load that supports this modle for unlocking HUAWEI T158 THANK YOU VERY MUCH. |
Huawei t158 unlock ok on vygis | el-safwa | VygisToolbox | 2 | 12-19-2014 16:51 |
Huawei t158 unlocking error | laxman kumar | Infinity-Box | 1 | 11-05-2009 11:51 |
HUAWEI T158 Unlocking all | 4 u man | Infinity-Box | 2 | 05-14-2009 12:58 |
kp100 and huawei T158 unlock ok... | ZIYAAD STRYKER | Infinity-Box | 0 | 02-14-2009 05:41 |
1000 pieces of Huawei T158 unlocked successfully | ericnite101 | Infinity-Box | 1 | 11-24-2008 07:53 |
