Old 11-15-2008, 11:36   #1 (permalink)
Member: 296122
Thanks Meter: 4
huawei t201 secuss unlock done
OM1 [Serial0] selected
module v1.54
Device: Huawei-T201
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set baud ...
115200
Set baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-sta...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_eeprom-sta_20081115-102057.B1E.bin
loading data...
data loaded
reading eeprom-sec...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_eeprom-sec_20081115-102102.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_eeprom-complete_20081115-102109.B1E.bin
reading additional data...
Done
backup critical area Done
Check memory ...
current status: 0
Check memory Done
write ...
Erasing: lock-area
Writing: lock-area
write Done
Finished, time used: 156 sec
Remove/Install battery now !
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
The Following User Says Thank You to hesn For This Useful Post:
Old 11-15-2008, 18:23   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 12-09-2008, 08:26   #3 (permalink)
Member: 767451
Thanks Meter: 178
arte you sure? bro many times i try but not done?
Old 12-09-2008, 09:25   #4 (permalink)
Member: 130995
Hello,
Thousands of people absolutely sure.
If you really have a problem make a detailed problem description.
Old 12-15-2008, 22:25   #5 (permalink)
Member: 174853
Thanks Meter: 84
i try to unlock huawei T201 but the model is not listed under Huawei?
Old 12-16-2008, 21:38   #6 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hello,
You must download and install latest updates from support area because we add new models and features several times per week !
Just go to support area and download updates !
The Following User Says Thank You to InfinityN For This Useful Post:
Huawei (BMOBILE) U120 unlock done,procedure inside... genehack Huawei 3 08-19-2011 07:50
huawei new t156 unlock done naveedbutt Trash 0 12-12-2009 07:48
Huawei Ufone T156 Unlock Done Tahir Riaz Infinity-Box 24 11-10-2009 20:35
Huawei T211 readed & unlocked as Huawei T201 [GOOD WORK] elcapitel PolarBox 3 0 10-28-2009 21:15
Page generated in 0.19920 seconds with 9 queries
