01-19-2009, 16:04 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | i need infinity's help..!! i killed a china cell :( COM5 [VCP7] selected module v2.74 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:A9C1:CECE high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash... |
01-19-2009, 17:01 | #3 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Hello, GOod afternoon What you can do is to MAKE a READ DETAILED INFORMATION and then you will get the FLASH FILE that was on the phone. The flash file might be on the WEBSITE support sever. THe above information you gave is insufficient.. Well i hope am right. Cheers. |
01-19-2009, 17:19 | #4 (permalink) |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | i've formatted it with safe formating mode with infinity and the cell is dead i tried to read and flash it but while reading it gave that error at the post #1 |
01-19-2009, 18:00 | #5 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Read which FLASH file? the dead phone? or you have another working set? What you have to do is to make a READ DETAILEDusing the infinity software. After that i can help you. Post the LOG here! |
01-19-2009, 19:50 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @kasrawiz This kind of log can not be a result of "safe format" due to software even can not detect phone firmware version. It looks like you have made "format whole flash chip" and as a result software give you this information: Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: check operation log file and find original phone firmware version. |
01-20-2009, 10:24 | #8 (permalink) | |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Quote:
tnanks to all for your replies | |
01-20-2009, 19:01 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! posted above log is empty, it is taken from phone with already erased flash. please open file named "operation.log" in chinese miracle folder. scroll it up from file end. look for operations which you made. find very first operation of this phone. there you will see phone Original firmware version. post it here. |
01-22-2009, 10:43 | #10 (permalink) | |
01-22-2009, 20:02 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! without knowing original software version it is quite hard. i just check our support area, and failed to find flash file by phone model name "6682". now the only way to find out original software version is to find same working phone. or maybe some of forum member will recognize it by photo |
01-24-2009, 12:29 | #12 (permalink) |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Thanks for all you people for your replies and Special thanks to Infinity for their kind support, i found the same working cell nokia 6682 and i flashed it with infinity and the cell is alive again now please tell me how to add this MTK_66682_M500TV_Y5_PCB01_GPRS_MT6226_S01[1].00_0_16m_En_Vn_w_eeprom.B0M in support area |
01-24-2009, 21:50 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
we have this firmware on support. whats for to add it? | |
China Market - Share Price Of China Cell | serchingeye | Infinity-Box | 0 | 05-21-2008 03:22 |
in desperate need of help - just killed w810i with usb smart | bigsam123 | Sony Ericsson | 3 | 02-15-2007 15:05 |
Cruiser keeps killing K700's after unlock... :( | James_S | Cruiser Suite | 15 | 06-30-2005 04:10 |
Killed 5110 by me :( | One | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-03-2003 16:26 |
