04-02-2007, 14:45 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | I cannot enter support till a month 1. You must download and use latest Support Manager to login in support area ! 2. Connect Dongle/Box to PC. 3. Install Support Manager and follow Support area link. but follow link not opened any pages.I use win 98 .pls check this error my dongle updated also.in support manager 'shell' also has dowland section but I click on 'aplication not found c:\program files\infinityBox message appear note:also suponsored links not work on shell for my comp pls check this error for win98 shel gets updates in his bar ownloading updates info... Connecting to server [http://www.infinity-box.com/download] ... Updated software modules: Client 1.02 PNModule 1.03 Moto02 1.37 Shell 1.10 VModule 1.22 VkMobile03 1.00 MModule 1.44 QCModule 1.06 ChineseMiracle 1.23 Moto03 1.04 Updates info finished but not open support site regards |
04-02-2007, 16:41 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Please, start Infinity-Box Shell and follow my advice (see picture to make correct clicks). If Shell not works I think some bugs in your Win98 installation and your PC. If you still have problems, please, make this: 1. double check that your PC works fine. 2. double check that your Win98 installation not damaged (mabe need to re-install it to make it work correct). 3. try to run Shell on other PC, I am sure this helps. 4. to make all software/links work pls download and install latest Installation package. |
04-02-2007, 17:01 | #5 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | dear support I was check shell the other 98 not work.I write my post your suponsor link also dead in shell in 98 .xp works perfeckt. ı want to use infinity in 98 can u check this bug pls. |
04-02-2007, 18:50 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Please, make detailed description what's happen when you click "Enter support/download area" button. It's interesting to see screenshots. Are you sure that you really tried to run "Shell" on other PC ? Are you sure that it was PC under Win98 ? To be honest I can't beleive that you tried on 2 your PC and both under Win98 and both not work. Just want to remind you that now year 2007 and it's very hard to beleive in 2 PC under Win98 (for member registered in 2001). Pls, tell me honestly what you really tried to do and what you did not tried to do. Please, no need to tell me about the same tests on 3rd or 4th PC under Win98, please, give me honest and detailed description. Also, pls, tell me what you see on your PC when you make this: "Start" -> "Run" -> type text: www.infinity-box.com -> "Ok" |
04-02-2007, 23:38 | #7 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | "Please, make detailed description what's happen when you click "Enter support/download area" button. It's interesting to see screenshots." answer is nothing. "Are you sure that you really tried to run "Shell" on other PC ? Are you sure that it was PC under Win98 ?" really meaning is strance.I test 2 pc and not enter support and also suponsored links from it. "To be honest I can't beleive that you tried on 2 your PC and both under Win98 and both not work. Just want to remind you that now year 2007 and it's very hard to beleive in 2 PC under Win98 (for member registered in 2001). Pls, tell me honestly what you really tried to do and what you did not tried to do. Please, no need to tell me about the same tests on 3rd or 4th PC under Win98, please, give me honest and detailed description." you not belive me.I have 5 pc in my shop 1-win98se 2-xpsp2 2-xp win98 xpsp2 3 sytems my purpose can work infinty in 98se for my shop due to setlement.Else I can set infinity to other with xp pc. What are you think any other? easyest way to belive someone test his words before to say.member from 2001 and post over 1000 ardagul not says to lie. ıf you work in gsm busines only xp not enought for u.at least for me. you can say infinity not support 98 that is ok.if not test shell in 98 pc yourself it is easyt way. I write this from home.If you still interest this thread and any comment tomorow I will in my shop. br |
04-03-2007, 18:48 | #8 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Please, read thread name that you started and compare with some info given by you (marked in yellow color). | |
04-03-2007, 22:25 | #9 (permalink) | |
Member: 7114 Status: Offline Thanks Meter: 51 | Quote:
today I take support with my labtop. but I cannot calculate yellow marked .! 2-xpsp2 xpsp2 member from 2001 and post over 1000 ardagul not says to lie. If you want to say someting pls say directly.And I can say to u.You are not best clever in the world.And you need also your custumer.you can sell best honey but if Your presantation offensive .I can prefer eat sugar with water,perhaps take care br | |
04-04-2007, 07:31 | #10 (permalink) | |
Here is explanation: Thread name that you started is: "I cannot enter support till a month" You have in your office PC with WinXP and you can enter in support area easily. This means that you lie. As a result of these your activity I prefer to wait some more user's replies about Infinity-Box and Win98 and after this I can see truth about problems (if exist). p.s. I hope next time you will try to write thread name and problem description w/o lie and give correct name for thread name and make good, clear and honest problem description. Last edited by InfinitySupport; 04-04-2007 at 07:44. | |
04-04-2007, 09:32 | #11 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | [QUOTE=InfinitySupport;2357747]Dear Friend, Here is explanation: Thread name that you started is: "I cannot enter support till a month" You have in your office PC with WinXP and you can enter in support area easily. This means that you lie. QUOTE] this is your logic,reality is my lived support problem 98se between infinity.I was say before u with xp can work but I just set yesterday in my labtop.and take support.noting is lie in my words. you can wait any other 98 problem from users and make decide to check shell bugs or can not interest this problem .this is your choice. I can say from mine side. infinity support not work with 98pc your dongle user ardagul br |
04-04-2007, 19:10 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Dear Friend, Hope next time you will make correct problem description but not insult people with words like "I cannot enter support till a month" instead of explain problem exactly and make thread name f.e. like "probably problem with support area access under Win98". Also best choice in this situation is: wait replies from other users who tried to use Infinity-Box on different OS/PC. |
04-04-2007, 21:09 | #13 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | my target is not insult people with my words,not now and never.probably I can write better thread name like your example. next time if I write someting to infinity support I will think double.I haven't more time to wait solution.Because you can wait to verify. br |
04-04-2007, 21:15 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Dear Friend, I don't think it's a big problem for you due to you have in office several PC under Win XP. Also, as you can see I asked you detailed description of problem but you ignored my questions here: http://forum.gsmhosting.com/vbb/show...87&postcount=6 Anyway, it's not important now because I prefer to wait some replies from other users to see what is the problem exactly (if exists) and see how this problem (if exist) depends on PC/OS. During last time several thousand users connected to new automatic support area w/o problems and nobody asked me about login problems under Win98 before. |
04-04-2007, 21:40 | #15 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | all question is answered, http://forum.gsmhosting.com/vbb/show...39&postcount=5 from first post note:also suponsored links not work on shell for my comp pls check this error for win98 Also, pls, tell me what you see on your PC when you make this: "Start" -> "Run" -> type text: www.infinity-box.com -> "Ok" only this one ,not nessesary this is my last post for this discuss sorry to all members regards to all |
Cannot Enter support AREA... Help!! | zakiyyboss | Infinity-Box | 1 | 06-20-2007 11:26 |
Cannot Enter support AREA... Help!! | zakiyyboss | Infinity-Box | 5 | 06-19-2007 16:45 |
