Old 10-19-2007, 10:10   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Chinese Blue Tooth 2.0 Not Connecting
I Am Having A Chinese Mobile
Blue Tooth 2.0 Is Written On It And It Comes With An External Zoom I Need Working Pinout For This Phone
Old 10-19-2007, 10:28   #2 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
here is the picture of this mobile
PLS NEED PINOUTS
Old 10-19-2007, 12:49   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
noone will help you if you will not provide following info:
1. connector type
2. where is located GND and charging pin
Old 10-19-2007, 13:34   #4 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
the connecter is 12 pin d800 socket
charging socket is on the bottom of the phone
the ground is located in the 5 point
Old 10-19-2007, 13:43   #5 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
am also waiting pinout for this mobile.
Old 10-19-2007, 13:48   #6 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
need pinouts ergently
Old 10-19-2007, 13:49   #7 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: read eeprom
Boot...
baud autodetection active
9600
Connecting, wait...
error: boot phase#2/1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 2 sec
Remove/Install battery now !
WHAT IS THIS ERROR
here is the log of the phone when i connect it to infinity
Old 10-19-2007, 14:21   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
@sahil2000ind
your problem: wrong pinout, please, read info below
@all
Dear Friends,
I have spend several hours this night and I have prepared extra-mega-detailed instruction and explanation especially for you so nobody can say to me that I am lazy. How about others ?
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 10-19-2007, 14:51   #9 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
i have connected the pins in about 36 different ways but it say the same problem
i dont feel lazy but i want that is any one have done it the they can help me in finding the right pinouts thats why i have putted the picture of this phone
BUT SEEMS THAT I AM UNABLE TO FIND THE RIGHT PINOUTS
Old 10-19-2007, 15:37   #10 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Got The Right Pinouts
CHINESE BLUE TOOTH 2.0 WITH ZOOM
9-grnd
8- Rx -tx
7- Tx-rx
Old 10-19-2007, 16:28   #11 (permalink)
Member: 130995
@sahil2000ind
thank you for your hard work
Old 10-19-2007, 16:32   #12 (permalink)
Member: 148515
helo sahil2000ind!
please confirm that phone pin 8 goes to pin 2 of box
an pin 7 of phone goes to box pin 3
or correct me
Old 10-20-2007, 07:41   #13 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Right Pinouts
9-grnd
8- Rx
7- Tx
Old 10-20-2007, 13:32   #14 (permalink)
Member: 185776
Thanks Meter: 73
Originally Posted by sahil2000ind View Post
Right Pinouts
9-grnd
8- Rx
7- Tx
DIid u formate the phone? What u did? Post the result.Thanks
Old 10-20-2007, 15:54   #15 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
The Rx & Tx are Printed on Board Just Above The B sim(U Need To open the handset).
Please Read the full Flash & EEprom & Send it to [email protected]
I need it Urgently.
Thanks & Regards
Shubhanshu
Blue tooth 2.0 bad software after format nilan SpiderMan 3 05-15-2008 08:04
blue tooth 2.0 bad software Imrankhan Infinity-Box 6 05-12-2008 13:31
China Mobile Blue Tooth 2.0 RASHED SAM Chinese Models & Cloned Phones 2 04-22-2008 07:24
Chines phone Blue Tooth 2.0 LV918 now_mobiles Infinity-Box 5 11-02-2007 16:24
Page generated in 0.29333 seconds with 9 queries
