09-12-2008, 12:48 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | i need help for find pinout i need pinout phone is dual sim cpu type 6226BA conector 1x20 and write N 328 PLEEASE HELP IS VERY VERY URGENT |
09-12-2008, 15:53 | #4 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Chinese Section Age: 37
Member: 594884 Status: Offline Thanks Meter: 1,553 | Quote:
Is there no any company name (Nokia, cect......etc)? plz show here to get pinout. .::Pinout Guiders::. .::skybird::. | |
09-12-2008, 16:14 | #5 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | if u have no success. please read this thread carefully and do as. http:///vbb/showthread.php?t=544521 http:///vbb/showthread.php?t=476373 ..::PinoutGuiders::.. |
09-12-2008, 18:58 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 3. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
09-13-2008, 08:55 | #7 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | hi my problem solved thanks INFINITYHELP and SHakeel_pattoki for info now pinout is conector1..............20 keypad top 19 20 GND 7 RX 8 TX |
09-13-2008, 08:59 | #8 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | here is logo COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:9719:9DBD high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: D09_LY_MT6226_V_237.BIN ver. sw2: V_2.3.7, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[D09_LY_MT6226_V_237.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\N328\flash[D09_LY_MT6226_V_237.BIN]_20080913-095502.B0M.bin Finished, time used: 435 sec Remove/Install battery now ! |
need help to find pinout in | delchoni | Infinity-Box | 9 | 03-02-2010 09:35 |
Need help for cable pinouts chines IPHONE 32GB | quickgsm | Chinese Models & Cloned Phones | 1 | 12-14-2009 16:30 |
need help to find pinout for 6500 slider china | fastlink Jogja | Infinity-Box | 1 | 10-18-2009 14:59 |
plz help for find pinout for zt678 | tarunvishal | Chinese Cocktail | 2 | 11-16-2007 14:17 |
Need help for 7210 pinout | Bert | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 10-05-2002 12:13 |
