05-04-2008, 14:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2007
Member: 493750 Status: Offline Thanks Meter: 28 | I need help for sagem 220v here the log COM1 [Serial0] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IO_141107_1557 141107_1557 EBI_IO Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220v_eeprom-sta_20080504-110212.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220v_eeprom-sec_20080504-110214.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220v_eeprom-complete_20080504-110219.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 61 sec I have restored the backup without succes and here the full flash http://rapidshare.com/files/11241818...5.B1X.bin.html |
05-04-2008, 15:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Dear Friend, You write here incorrect (false, dishonest, wrong) information. You phone can not be dead by one simple reason: according to log that you have posted Infinity-Box software just read some data from your phone and stopped to work due to it was unknown firmware. No data was written into phone so phone can not be damaged. Please, be so kind, charge the battery and try to power on your phone again. Please, next time read information in software log window to avoid this kind of problems and messages. What to do after battery charging: download latest updates from Infinity-Box support area. |
05-05-2008, 11:00 | #3 (permalink) | |
Member: 493750 Status: Offline Thanks Meter: 28 | Quote:
COM3 [VCP0] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220v_eeprom-sta_20080503-111612.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220v_eeprom-sec_20080503-111622.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220v_eeprom-complete_20080503-111625.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area repair write error [0048B800]... error: write failed[00450000] Write Failed Finished, Remove/Install battery now ! Time used: 97 sec then the phone is dead | |
05-05-2008, 20:09 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @hassenmobile pls, send a mail with problem explanation to [email protected] so we will be able to prepare some files for you. include first log in your e-mail (/vbb/showpost.p...99&postcount=3) |
05-06-2008, 09:49 | #6 (permalink) | |
I need help for Sagem MY150X sp-lock | chronic | Infineon C16X M51 & ARM7 M52 BASED | 5 | 12-15-2007 13:11 |
need help for sagem myx-3 unlock code | GazI | Phone Unlocking Codes & Maps | 4 | 09-08-2003 15:40 |
need help for sagem 3026 | GazI | Phone Unlocking Codes & Maps | 5 | 08-29-2003 10:27 |
Need help for SAGEM MW3026 | TheMagicMan | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-19-2002 19:56 |
I need help for Sagem MC920 | DrMobile | Infineon C16X M51 & ARM7 M52 BASED | 9 | 04-06-2002 06:07 |
