Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
04-04-2002, 16:38 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | I need help for Sagem MC920 any know i can repair phone which is Simlocked with out sim card and HOW to reset counter. Waiting for reply, Thanks Wahab |
04-04-2002, 17:27 | #2 (permalink) |
No Life Poster Join Date: Mar 2002
Member: 10175 Status: Offline Thanks Meter: 0 | Check, if your IMEI is correct... Use SagemDr to correct the IMEI. (Do not only correct field 0) Then use option 9 -> Verify Checksums (Use standardvalues except for field 251. Enter the data manually, enter "40" instead of "41". This should help. Bye, Chris |
04-05-2002, 04:00 | #4 (permalink) |
No Life Poster Join Date: Jul 2000 Location: The Netherlands Age: 43
Member: 1688 Status: Offline Thanks Meter: 1 | Found sagemdocter 14c plus when i try function 9 geat a error: -------------- Phone I/O: ------------------------------------------------------ answer: FF read_prom error: timeout while waiting for answer. Retrying... sending command: 02 06 D2 05 00 44 00 00 97 03 answer: FF FF FF FF FF read_prom error: timeout while waiting for answer. Retrying... sending command: 02 06 D2 05 00 44 00 00 97 03 read_prom error: timeout while waiting for answer. Reading prom failed for 3 times: Check connection... Retry? (Y/n) ----------------------------------------------------------------------------------- Why ?????? |
04-06-2002, 02:43 | #7 (permalink) |
Member: 10175 Status: Offline Thanks Meter: 0 | @Magic2ik What Firmware do your sagems have? - At first make a backup of the phones (if something goes wrong, you can go back to the yet-state) - Change IMEI to something... (Don't correct the checksums) - Change IMEI back to original IMEI (see the sticker on the phone) (don't correct the checksums) Either it works now or you get the message simlocked... The further action depends on the firmware of your phone. If your Firmware is older than FT 4.1M or FW 4.1M you can just write 00 to field 251 / 252 / 253 and then correct the checksums (Option 9) For field 251 manually enter the value 40 For the other fields you can let sagemdr take the standardvalues... If your firmware is newer, please ask again and I'll tell you. Bye, Chris |
04-06-2002, 02:50 | #8 (permalink) | |
No Life Poster Join Date: May 2000 Location: Malaysia and Singapore Age: 49
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Hi Magic2ik, What is your phone version? maybe I can help....... b.r. Vid Quote:
I need help for Sagem MY150X sp-lock | chronic | Infineon C16X M51 & ARM7 M52 BASED | 5 | 12-15-2007 13:11 |
need help for sagem myx-3 unlock code | GazI | Phone Unlocking Codes & Maps | 4 | 09-08-2003 15:40 |
need help for sagem 3026 | GazI | Phone Unlocking Codes & Maps | 5 | 08-29-2003 10:27 |
Need help for SAGEM MW3026 | TheMagicMan | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-19-2002 19:56 |
