Old 01-19-2009, 16:04   #1 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
i need infinity's help..!! i killed a china cell :(
infinity please help i need this flash file i was trying to read and rewrite it gave me the following error what is it ?
COM5 [VCP7] selected
module v2.74
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:A9C1:CECE
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: flash...
Old 01-19-2009, 16:14   #2 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 227
do u format the phone with whole flash formating ?
Old 01-19-2009, 17:01   #3 (permalink)
Member: 64823
Thanks Meter: 439
Hello, GOod afternoon
What you can do is to MAKE a READ DETAILED INFORMATION and then you will get the FLASH FILE that was on the phone. The flash file might be on the WEBSITE support sever.
THe above information you gave is insufficient.. Well i hope am right.
Cheers.
Old 01-19-2009, 17:19   #4 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
i've formatted it with safe formating mode with infinity and the cell is dead i tried to read and flash it but while reading it gave that error at the post #1
Old 01-19-2009, 18:00   #5 (permalink)
Member: 64823
Thanks Meter: 439
Read which FLASH file? the dead phone? or you have another working set? What you have to do is to make a READ DETAILEDusing the infinity software. After that i can help you. Post the LOG here!
Old 01-19-2009, 18:17   #6 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
open ur set
give enough heat to its cpu and flash ic.
reball these both ic,s.
then format it and change imei.
and enjoy
Old 01-19-2009, 19:50   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
@kasrawiz
This kind of log can not be a result of "safe format" due to software even can not detect phone firmware version.
It looks like you have made "format whole flash chip" and as a result software give you this information: Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do: check operation log file and find original phone firmware version.
Old 01-20-2009, 10:24   #8 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
Originally Posted by InfinitySupport View Post
@kasrawiz
thanks for your reply i know this is not safe format logs, i formated the cell and i turn the software off and tried to turn on but it couldn't be on so i tried to read the dead cell and write it back it gave me the empty chip error so where to get it's flash file can anyone please add here and i couldn't find it in support area too
tnanks to all for your replies
Old 01-20-2009, 19:01   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
posted above log is empty, it is taken from phone with already erased flash.
please open file named "operation.log" in chinese miracle folder.
scroll it up from file end. look for operations which you made.
find very first operation of this phone. there you will see phone Original firmware version.
post it here.
Old 01-22-2009, 10:43   #10 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
hello!
post it here.
i've opened the Operation.log there wasn't any log for Nokia 6682 because i've installed the new update pack of the ChineseMiracle now tell me what to do
Old 01-22-2009, 20:02   #11 (permalink)
Member: 148515
hello!
without knowing original software version it is quite hard.
i just check our support area, and failed to find flash file by phone model name "6682".
now the only way to find out original software version is to find same working phone.
or maybe some of forum member will recognize it by photo
Old 01-24-2009, 12:29   #12 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
Thanks for all you people for your replies and Special thanks to Infinity for their kind support, i found the same working cell nokia 6682 and i flashed it with infinity and the cell is alive again now please tell me how to add this MTK_66682_M500TV_Y5_PCB01_GPRS_MT6226_S01[1].00_0_16m_En_Vn_w_eeprom.B0M in support area
Old 01-24-2009, 21:50   #13 (permalink)
Member: 148515
hello!
we have this firmware on support. whats for to add it?
Old 01-25-2009, 14:22   #14 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
that is great then i couldn't find this in support site so i thought to add thanks anyway
China Market - Share Price Of China Cell serchingeye Infinity-Box 0 05-21-2008 03:22
in desperate need of help - just killed w810i with usb smart bigsam123 Sony Ericsson 3 02-15-2007 15:05
Cruiser keeps killing K700's after unlock... :( James_S Cruiser Suite 15 06-30-2005 04:10
Killed 5110 by me :( One Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-03-2003 16:26
Page generated in 0.26051 seconds with 9 queries
