Old 11-20-2015, 05:51   #1 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
I9500 nand read ok but bad file
I read successfully i9500 nand file but when I try to load is says bad file
How to recover this file now?
Thank you
Old 11-20-2015, 06:05   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
nand write not activated yet
if u read as FF use sptool for write its
The Following User Says Thank You to sneha For This Useful Post:
Old 11-20-2015, 11:27   #3 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
readed as ispff ...how to write in sptool
Old 11-20-2015, 12:54   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
.ispff cannot be used with SPFT, it's specific Infinity readed file and can only be used with Infinity CM2.
If phone has MT6571/6572 Nand read factory firmware (scat) and then you can use it with SPFT.
Br.
Old 11-20-2015, 14:46   #5 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
It's 6572 nand cannot read factory firmware. Now phone in dead condition, cannot read file
Old 11-20-2015, 14:51   #6 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
MT6572 Nand is supported for ff reading, just make sure read info is success or check Nand Extra box.
Try to find other same model and read ff from it and write via SPFT.
Br.
Old 11-20-2015, 16:09   #7 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
upload ur readed file
post the link
Jaydi will make scatter file from it for u
Old 11-21-2015, 09:13   #8 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
I will not make FW. It very long and strange way. Plan make in one button converter for such. If it will work.
NAND will read IN ANY CASE with enabled NAND EXT.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-21-2015, 09:35   #9 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
waiting for application ....
thank you
Old 11-22-2015, 16:20   #10 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
Got another phone with same version
http://forum.gsmhosting.com/vbb/11423213-post6.html
I'll follow this and I'll pay results
Old 11-22-2015, 16:49   #11 (permalink)
JayDi's Avatar
Member: 462970
Read FW with "NAND Ext" option and flash to faulty one with SPFT after.
Page generated in 0.18559 seconds with 8 queries
