07-24-2016, 15:01 | #125 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
You can also read fw almost from any NAND phone by using NAND extra option. | |
07-24-2016, 15:01 | #126 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @abdulhaq_majroh, I will ban your dongle, if you not stop spamming here. 1. USE CODE TAG. 2. POST LOGS IN ONE MESSAGE! Don't make thousands of them. 3. Use search. It helps! |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
07-24-2016, 17:54 | #129 (permalink) | |
Freak Poster Join Date: Apr 2012 Location: World Age: 37
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | Quote:
Please right click on program => Proprieties => Compatiblity tab => compatiblity mode and select windows7. Apply run program and repeat operation again. | |
07-25-2016, 09:15 | #130 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,989 | Dear Sir, If you want to report a problem for one specific phone please create one separate thread for your problem. Thank you ! Last edited by YellowBoss; 07-25-2016 at 09:26. |
07-26-2016, 13:10 | #135 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: Indonesia
Member: 919549 Status: Offline Thanks Meter: 132 | Quote:
Paternlock Code: Start at : [24/07/2016 / 16:02:56] Operation : Read Pattern/DP Lock [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x017EA7621B2B897E9DB2CAFC2B8C0C8C INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... Get Locks ... PatternLock Sequnce : 3214789 Done! Elapsed: 00:02:00 Reconnect Power/Cable! Finish at : [24/07/2016 / 16:04:57] Code: Start at : [24/07/2016 / 16:14:21] Operation : Read Flash [ v1.53 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 30 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : 0x017EA7621B2B897E9DB2CAFC2B8C0C8C INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_s806.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6571 / V1.1.1 / s806 / NAND FW Size : 239 MiB Brand : ADVAN S3 ProdName : ADVAN S3 ProdModel : ADVAN S3 Device : S806-S39 AndroidVer: 4.2.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.JB7.MP.V1.14 Android Info saved Scatter saved to : C:\Users\a1\Desktop\Advand S3 Nand\MT6571_NAND_ADVAN S3__ADVAN S3__S806-S39__4.2.2__ALPS.JB7.MP.V1.14 Done! Elapsed: 00:02:58 Reconnect Power/Cable! Finish at : [24/07/2016 / 16:17:20] | |
The Following User Says Thank You to anoamocreative For This Useful Post: |
