![]() | #91 (permalink) |
Major Poster ![]() ![]() Join Date: Oct 2009 Location: Minsk Age: 40
Member: 1146373 Status: Offline Sonork: 100.1618796 Thanks Meter: 1 | Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 22.07.2016 10:18:40 ---------- DongleManager [Infinity-Box] v1.63 [22.07.2016 10:18:40] PC HWID: xxxxxxxxxxxxxxxxxxxxxx Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: xxxxxxxxxxxxxxxxxxx Type: Main Infinity-Box/Dongle S/N:xxxxxxxxxxxxxx Version: 0130.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. No updates found for your Smart-Card. DO NOT try more today ! there is a solution? |
![]() | #92 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Where you live
Member: 462970 Status: Offline Thanks Meter: 20,353 | Quote:
![]() About second one - will try to find sample. Also, if you have any link over net with it description - send me it for check. Can't find it over google. | |
![]() | #95 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 46
Member: 138982 Status: Offline Thanks Meter: 138 | I had downloaded The latest MTK 1.53 bt i still get dongle firmware upgrade error. i had also valid support area Allowed today: 40 Downloaded today: 0 Downloaded total: 4 Valid: 2017-01-18. But still it show latest firmware in card. Need urgent help cause my work stops Thanking you salim |
![]() | #96 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2016 Age: 35
Member: 2516015 Status: Offline Thanks Meter: 100 | Quote:
Sent from my GT-I9305 using Tapatalk | |
![]() | #97 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Nov 2015 Location: walton road lahore cantt
Member: 2490362 Status: Offline Sonork: 100.1675622 Thanks Meter: 31 | Qmobile S2 Pro Flash file Qmobile S2 Pro Flash file Readed From Cm2 MT6580__QMobile__S2_Pro__S2_Pro__6.0__ALPS.W10.24. p0 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : S2_Pro Device CPU : MT6580 Device IntName : QMobile_S2_Pro Device Version : 6.0 Device Compile : 6/3/2016 6:16:01 AM Device Project : ALPS.W10.24.p0 Device ExtInfo : S2 Pro Last edited by THE CLASH; 07-22-2016 at 20:49. |
![]() | #103 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | DongleManager [Infinity-Box] v1.61 [7/23/2016 12:07:59 PM] PC HWID: A839B67B760EA79F29A18B5996334508 Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000102E00001942 Type: inf S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0010] Dongle authentication failed. Contact to [email protected] |
![]() | #104 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Oct 2011 Location: Plat M-Plat N
Member: 1674834 Status: Offline Thanks Meter: 6 | and this is the second time you see MT6580 with NAND Flash ![]() Operation : Check / Read Info [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 102 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0053 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/00 DEV RID : 0x4F885C91026530C774A1CE4F9BD64EC7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done ![]() You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:07 Reconnect Power/Cable! MTK Droid Tools logs Hardware : MT8321M Model : X7 Plus Build number : X7 Plus/S9719/V11/20160525 Build date UTC : 20160525-085031 Android v : 5.1 Baseband v: MOLY.WR8.W1449.MD.WG.MP.V13.P4, 2016/03/28 16:17 Kernel v : 3.10.72+ (weirq@hzsw06) (gcc version 4.8 (GCC) ) #1 SMP Wed May 25 17:01:22 CST 2016 this devise is Tab Advan Vandroid X7 Plus 7" (Indonesian) so, please add full support for all MTK with NAND Flash We believe Infinity Team will make it real :-) we waiting.. Regard. |
![]() | #105 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2011 Location: Kabul City Afghanistan Age: 38
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | Operation : Check / Read Info [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00EC00BC00000066005600EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008E , [SAMSUNG] KF94G16Q4V [NAND] : FLASH_DIE : 00EC 00BC 0000 0066 0056 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : 0x7046A572CAE30373DB7268F420E97F3D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done ![]() You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following 11 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
