03-31-2019, 13:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | itel a16 plus 8.1 signed firmware flash write done Code: Set mode to : SP [SC773x] eMMC [Android 7.x] Loading : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 FastCheck : 0x005B908760 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img File : sp7731e_1h10.xml Load Ok! Operation : Read NV [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:30 Reconnect Power/Cable! Set mode to : [AltLDR] SP [SC773x] eMMC [Android 7.x] Loading : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 FastCheck : 0x005B908760 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img File : sp7731e_1h10.xml Load Ok! Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:30 Reconnect Power/Cable! Set mode to : [AltLDR] SP SC77xx [Model Select] Loading : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 FastCheck : 0x005B908760 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img File : sp7731e_1h10.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x20 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : w_fixnv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : VBMETA Current File : vbmeta-sign.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W_DELTANV Current File : delta_nv.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_GSM Current File : PIKE2_DM_DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DFS Current File : pike2_cm4.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : GPS_GL Current File : gnssbdmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : GPS_BD Current File : gnssmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : PM_pike2_cm4.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : VENDOR Current File : vendor.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_W Current Part : w_runtimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : CODE Current ID : TRUSTOS Current File : tos-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SML Current File : sml-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! Elapsed: 00:05:21 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to kothamamun For This Useful Post: |
04-01-2019, 04:11 | #4 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | here is your link without password itel_A16_Plus_SC7731_20180907_8.1.0_SPD |
The Following 2 Users Say Thank You to kothamamun For This Useful Post: |
04-01-2019, 09:11 | #5 (permalink) | |
No Life Poster Join Date: May 2009 Location: Bangladesh Age: 30
Member: 1034743 Status: Offline Sonork: 100.1619212 Thanks Meter: 193 | Quote:
The Following User Says Thank You to shaongsm For This Useful Post: |
04-01-2019, 14:35 | #6 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Quote:
The Following User Says Thank You to Oyetunde Semiu For This Useful Post: |
04-01-2019, 14:48 | #7 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | |
The Following User Says Thank You to kothamamun For This Useful Post: |
04-01-2019, 15:47 | #8 (permalink) | |
Member: 2812901 Status: Offline Thanks Meter: 493 | Quote: | |
04-04-2019, 15:39 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
