Old 03-31-2019, 13:20   #1 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
itel a16 plus 8.1 signed firmware flash write done
Set mode to : SP [SC773x] eMMC [Android 7.x]
Loading    : A16Plus-SA332-8.1-OP-V004-20180907.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : sp7731e_1h10
PacVersion : A16Plus-SA332-8.1-OP-V004-20180907
FastCheck  : 0x005B908760
Loading files ...
File : fdl1-sign.bin
File : fdl2-sign.bin
File : pike2_pubcp_PLD_base_nv_nvitem.bin
File : prodnv.img
File : u-boot-spl-16k-sign.bin
File : vbmeta-sign.img
File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat
File : delta_nv.bin
File : PIKE2_DM_DSP.bin
File : pike2_cm4.bin
File : gnssbdmodem.bin
File : gnssmodem.bin
File : PM_pike2_cm4.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : vendor.img
File : tos-sign.bin
File : sml-sign.bin
File : u-boot-sign.bin
File : persist.img
File : sp7731e_1h10.xml
Load Ok!
Operation : Read NV [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 5 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Something went wrong :(
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:30
Reconnect Power/Cable!
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 7.x]
Loading files ...
File : prodnv.img
File : delta_nv.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : vendor.img
File : tos-sign.bin
File : sml-sign.bin
File : persist.img
Load Ok!
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 5 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:30
Set mode to : [AltLDR] SP SC77xx [Model Select]
Loading files ...
File : prodnv.img
File : delta_nv.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : vendor.img
File : tos-sign.bin
File : sml-sign.bin
File : persist.img
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : A16Plus-SA332-8.1-OP-V004-20180907.pac
File : prodnv.img
File : delta_nv.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : vendor.img
File : tos-sign.bin
File : sml-sign.bin
File : persist.img
3. Insert cable
Phone found! [ 5 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x20 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : NVM Update
Current ID   : NV_W
Current Part : w_fixnv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : VBMETA
Current File : vbmeta-sign.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W_DELTANV
Current File : delta_nv.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_GSM
Current File : PIKE2_DM_DSP.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DFS
Current File : pike2_cm4.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : GPS_GL
Current File : gnssbdmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : GPS_BD
Current File : gnssmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : PM_pike2_cm4.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : VENDOR
Current File : vendor.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_W
Current Part : w_runtimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : TRUSTOS
Current File : tos-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : SML
Current File : sml-sign.bin
Flashing now ...
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:05:21
The Following 6 Users Say Thank You to kothamamun For This Useful Post:
Old 03-31-2019, 14:50   #2 (permalink)
Member: 2812901
Thanks Meter: 493
Please ! share the file with us without security sir
The Following User Says Thank You to Oyetunde Semiu For This Useful Post:
Old 03-31-2019, 15:25   #3 (permalink)
BraveNewWorld's Avatar
Member: 150193
Thanks Meter: 93
https://mega.nz/#!jewR3DqL!ZnNMCe6tb...53EwBhIPWRSCVk
The Following 2 Users Say Thank You to BraveNewWorld For This Useful Post:
Old 04-01-2019, 04:11   #4 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
here is your link without password
itel_A16_Plus_SC7731_20180907_8.1.0_SPD
The Following 2 Users Say Thank You to kothamamun For This Useful Post:
Old 04-01-2019, 09:11   #5 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
thanks, giving your free file
The Following User Says Thank You to shaongsm For This Useful Post:
Old 04-01-2019, 14:35   #6 (permalink)
Member: 2812901
Thanks Meter: 493
pls sir i need A16 v007 !
Old 04-01-2019, 14:48   #7 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
https://mshare.io/file/y7iUSZY
The Following User Says Thank You to kothamamun For This Useful Post:
Old 04-01-2019, 15:47   #8 (permalink)
Member: 2812901
Thanks Meter: 493
anyway thank for this, i download it but it is itel A16 V003 not itel A16 V007 sir. pls anyone with this itel A16 V007 share me a link or advise me if itel A16 v017 can work with v007.
Old 04-02-2019, 12:17   #9 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
just flash 007 it will be worked fine
Old 04-04-2019, 15:39   #10 (permalink)
Member: 148515
Thanks Meter: 19,534
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Please do not upload password protected or damaged files, all of them will be deleted after upload.
Thank you !
Old 04-04-2019, 16:22   #11 (permalink)
Member: 2812901
Thanks Meter: 493
I don't have v007 and nobody had free link to share me without password. Please if you have it share me
Old 04-16-2020, 13:08   #12 (permalink)
Member: 1233698
the download link is not working sir
The Following User Says Thank You to tapasmiah For This Useful Post:
Page generated in 0.22368 seconds with 8 queries
