02-23-2018, 06:46 | #184 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Here u can download Index of pub/ |
The Following 3 Users Say Thank You to princesaddam For This Useful Post: |
02-23-2018, 08:30 | #185 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Here is a good starting point - https://www.infinity-box.com/support/ |
02-27-2018, 14:21 | #186 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | ALcatel 5054T Frp remove done Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01BE9605 ID_BLOCK_L : 826218E651DDCAC5A2977966A1F87850 ID_BLOCK_L : 95E856F9FA65D55E734217CCC629C704 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : TCL ProdName : 5054T ProdModel : 5054T Device : Pop355 AndroidVer: 5.1.1 Manufact. : TCL SysPatch : LMY47V DevComTime: 10-12-2015 AM 11:06:11 QLMxCPU : MSM8909 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:20 Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01BE9605 ID_BLOCK_L : 826218E651DDCAC5A2977966A1F87850 ID_BLOCK_L : 95E856F9FA65D55E734217CCC629C704 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
02-28-2018, 09:13 | #188 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Did you mean can Infinity-Box [BEST] can be used for servicing chinese phones? Answer is No, since it's made only for servicing N0kia/Micr0s0ft/HMD phones. There is only one way to do so-activate main Infinity-Box software on your Infinity-Box [BEST]. Then you can use all modules of Infinity-Box including Chinese Miracle 2 to service all chinese based brands as well as branded phones like Lenovo, Moto, Lava, Oppo, Vivo etc. Br. Infinity Box Team. |
02-28-2018, 12:20 | #189 (permalink) |
Freak Poster Join Date: Apr 2017 Location: algeria
Member: 2704296 Status: Offline Sonork: 100.1677478 Thanks Meter: 30 | Hello Sir, According to my bad experience (link below, and my fone is dead) which I did not have any answer, http://forum.gsmhosting.com/vbb/f296/problem-flashing-cm2qlm-2351004/ I have one suggestion : Why do not add Selectif flash option on CM2QLM, it means have the choice to flash a parts of flash (e.g: boot or recovery or userdata...) not full flash like Z3X do with samsung ? Best Regards |
02-28-2018, 17:47 | #191 (permalink) | |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
CM2 Alrdy Added tht funtion it is called Memory tool u can find more abt it here http://forum.gsmhosting.com/vbb/f296...anual-2179982/ Abt ur mble prblm can u plz do Memory Test | |
The Following User Says Thank You to princesaddam For This Useful Post: |
02-28-2018, 22:02 | #192 (permalink) | |
Member: 2704296 Status: Offline Sonork: 100.1677478 Thanks Meter: 30 | Quote:
Y are realy a genious Thanks so much for help | |
