Old 08-22-2017, 16:51   #1 (permalink)
Liton_Bkash's Avatar
Member: 1821096
Sonork: 100.1650210
Thanks Meter: 346
Lava A3 mini Frp done By CM2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 186 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019061344741070FA432731C7094
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GA
[eMMC] : FLASH_CID : 90014A484147346132A40F0794701473
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xA9AF9D77445A3B658B83B177556AC241
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : LAVA
ProdName : A3_mini
ProdModel : A3_mini
Device : A3_mini
AndroidVer: 7.0
MTKxCPU : MT6737T
MTKxPRJ : alps-mp-n0.mp1-V1.0.2_lava6737t.65.g.n_P4
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:22
BR,
Liton_Bkash
The Following 2 Users Say Thank You to Liton_Bkash For This Useful Post:
Old 08-22-2017, 17:00   #2 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
Good information For security Boot Device....
Old 10-08-2017, 07:05   #3 (permalink)
Member: 2274875
Sonork: ?
Thanks Meter: 298
i have trying... but allways result faild... and i succed with this methoud >> https://goo.gl/Mq3hRr
Old 12-17-2017, 17:18   #4 (permalink)
Member: 1236922
Sonork: sajer007
Thanks Meter: 101
Smile A3 mini frp done
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM10
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6735
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CA00
>>> Initialization Mobile ...Success
>>> Downloading Boot1 To Mobile Phone...Success
The Flash Hardware Info:JHAG4a
>>> Downloading Boot2 To Mobile Phone...
>>> Initializationing Mobile Hardware Parameter...Success
=====================Flash Type(eMMC)==============
Flash Size: 0x00000003AB400000 -> 15028M
Flash ID: 0x90014A4841473461
Flash Name: Hynix_Unknow
Flash symbol: JHAG4a
>>> Software Auto Switch Hight Speed Has Enable...
>>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM31
MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Success
>>> Extracting valid data from partition data...
>>>>Formating Mobile USER Data...
ADD(HEX):0x0006A00000 Size(HEX):0x0000100000
Corresponding operation completed!!!
Old 12-18-2017, 06:30   #5 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
MediaTek USB Port
CPU_NAME: MT6735
You post wrong section,,,,
post Correct Section plz... others was team delete your post......
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post:
Page generated in 0.15882 seconds with 8 queries
