04-04-2011, 03:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: ahmedabad gujaratr Age: 41
Member: 221464 Status: Offline Thanks Meter: 6 | Inifinity with spice mobile |
04-04-2011, 07:51 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Friend, why you lie ? Many Spice phones supported by Infinity-Box. Look here: www.infinity-Box com Spice: D80, D88, D88N, D90, M3636, M4242, M4580, M4580DV, M5050, M5151, M5161, M5161n, M5252, M6000, M6060, M6262, M940N, QT-44, QT-50, QT-52, QT-55, S300, S400, S404, S404N, S410, S415, S450, S5, S500, S5110, S525, S530, S5330, S535, S540, S545, S555, S570, S580, S590, S600, S600N, S640, S650, S7, S700, S7000, S705, S707, S707n, S710, S8, S800, S808, S820, S9, S900, S920, S940, X1, other Do you need more ? I have a solution: http://forum.gsmhosting.com/vbb/f296...dates-1199864/ |
04-18-2011, 12:25 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Jodhpur India
Member: 48238 Status: Offline Sonork: 100.54361 Thanks Meter: 397 | Hi Specially for spice 5454 as it is different hardware based it has no connectivity with PC follow this Instruction for S/W updating via T Card Updating Steps Step 1: Format T card before updating and make sure to set T card as FAT16/FAT32 format. (Note: the previous software is only compatible with FAT16 format) Step 2: Copy the folder KKUpdate and move it to T card root directory Copy two files, Bin file and scat (txt file) to KKUpdate Step 3: Make sure T card is inserted into the phone. For the dual-T card handset, please make sure T card is inserted into card slot 1 Step 4: Updating Option A) Updating when handset works in normal operation condition Access to engine mode with code ‘*#01478963# ’, and then select option ‘update start’ to start S/W updating (Engine mode is not opened to end-user) Option B) Updating when handset can’t be started up Long-press ‘power’ + ‘5’ key to start S/W updating Step 5: After few seconds, LCD screen will display updating information and indicate the updating progress. When updating is done, phone will be rebooted automatically. Warning a) This S/W updating instruction is appointed as standard updating procedure. Please discard any previous updating instruction. This instruction is applied to the latest T card updating (MTK 53 platform). b) This S/W updating with T card support is a smart updating method which has comprehensively considered all situations including such as handset can’t be started up. If handset can be started up normally, the Updating Option A (access to engine code to start updating) must be utilized. Otherwise, please select Option B (Long-press power key to start updating) WBR Jyoti |
04-19-2011, 17:49 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Very good. please, send files to [email protected] and we will upload it in support area for all users. |
08-29-2011, 12:26 | #9 (permalink) | |
Junior Member Join Date: Aug 2006
Member: 327196 Status: Offline Thanks Meter: 2 | Flash Fil Location?????????????? Please provide me M-5454 Flash File Quote:
08-30-2011, 03:31 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Support area with M5454 files is here: download area |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
