Old 04-05-2008, 11:18   #1 (permalink)
Member: 13345
Thanks Meter: 16
IPhone A8+
Need a bit of help please. Can i unlock this phone with the supplied usb cable and if so does any one have the drivers. Although i have had infinity box for over a year i have never had a chinese miracle to unlock.
WBR
Richie40
Old 04-05-2008, 17:35   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You need to use Rx/Tx/Gnd cable.
Old 04-05-2008, 17:52   #3 (permalink)
tuli's Avatar
Member: 511615
Thanks Meter: 35
only with rj45 cable you can connect it
Old 04-05-2008, 19:10   #4 (permalink)
Member: 13345
Thanks Meter: 16
Thank you for your help.
Old 02-08-2009, 18:53   #5 (permalink)
Member: 403517
Thanks Meter: 23
hi, im unlocking its model iphone chinesse A8+
i have pinout
pin 2 GND
pin 3 RX
pin 4 TX
B.R
ZACHI
http://forum.gsmhosting.com/vbb/showthread.php?t=490339&highlight=a8
its the log
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:542E:F17D
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version:
1.0
Version: A8P-MUL_G60MPv01.01b03
Version: G60M_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35719801314856
connection Ok
detecting structure #1...
0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29error: detection failed (27 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 104 sec
Remove/Install battery now !
i have error in pinout , any solution?
thanks for yours help!
br
evaca26
Old 02-08-2009, 19:50   #6 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 90
take option for standard method do not take read codes
Old 02-08-2009, 21:13   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
make format FFS complete, code will gone
Old 02-09-2009, 18:14   #8 (permalink)
Member: 403517
Thanks Meter: 23
need help! format FFS complete dead iphone ?
need flash file !
please help me!
br
evaca26
Old 02-09-2009, 18:27   #9 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
need flash file !
please help me!
br
evaca26
hi..
did u check the support..? at first pls check support for flash fle..then if not exist on support page pls add here ur fw details...
b.r.
Old 02-09-2009, 20:06   #10 (permalink)
Member: 148515
hello!
make format FFS and check if it helps or not.
if not- find flash file by your phone original software version.
need flash file !
please help me!
br
evaca26
Old 02-09-2009, 22:45   #11 (permalink)
Member: 403517
Thanks Meter: 23
its log
COM5 [VCP0] selected
module v2.76
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
boot packet size: 0002
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.86089D9E.[SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN_36CF8AEF].rpl
identification#1 detection finished
device-id: 86089D9E
identification#1 protocol ver: 04
ver. sw 1: SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN
ver. sw 2: A8P-MUL_G60MPv01.01b03, 107530C9
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN]...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\eeprom[SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN]_20090209-153453.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\system_log_86089D9E_SIMC26_06B_PCB01_GPRS_MT6226 _S01.A8P-MUL_G60MPV01_01B03.BIN_36CF8AEF_20090209-153510.B0X.bin
Finished, time used: 411 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
not power on , but the box recognizes the iphone
need the flash file original iphone chinesse A8+, where can I get?
thanks for help me!!!!!!!!!!!!!!
Old 02-10-2009, 15:47   #12 (permalink)
Member: 403517
Thanks Meter: 23
i need help InfinityHelp plz!
Old 02-10-2009, 17:29   #13 (permalink)
Member: 403517
Thanks Meter: 23
ffs the procedure and then write the EPROM and is now ready
unlock ok 100 %
br
evaca26
HELP how to unlock iphone 3.1 laksh007 iPhone 2 / iPhone 3G / iPhone 3GS 7 03-31-2010 03:22
pinaoit for CECT iphone A8+ Dual Sim PDA adelgsm Infinity-Box 0 08-16-2008 19:11
Need full MCU dump from Audi (Blaupunkt) concert A8/chorus A8 fabi_pl CAR Electronics 2 07-24-2008 11:05
iphone clone awang a8+ Mobileee Chinese Models & Cloned Phones 0 03-18-2008 18:08
Timeport a8.13.10 - Tamper Alert! How to clear??? Kiryu-ha Motorola Old Legacy (EMMI) 1 05-08-2002 16:43
Page generated in 0.22641 seconds with 10 queries
