Old 07-10-2008, 08:34   #1 (permalink)
Member: 204684
Thanks Meter: 21
KG130 blue sreen after flash
Hello Infinity Support!
I had LG KG130 with version: ***-XXV10fEURKG130P40
I flashed it with version: ***-XXV10a07KG130P40 and after that my phone sreen apear blue. I can make or recive calls but nothing hapens on the sreen.
I've searched this version on support site adn I didn't find it...
So what do I have to do to resolve this problem?
Here is log after first flashing:
Application: C:\Program Files\InfinityBox\LGA\LgA.exe
Loading data, wait...
[Infinity Box] v1.30
S/N: 373B:010F
Wait...
Current device: LG B2000
Done
Current device: LG KG130
Loading file v.02...
KG130P40-07-v10a_***-XX_MAY-14-2007_code[1].B1M.bin loaded
KG130P40-07-v10a_***-XX_MAY-14-2007_alchemy[1].B1P.bin loaded
Testing COM1 at 921600...
COM1 [Serial0] selected
error: can't open COM1
COM8 ready
Testing COM8 at 921600...
COM8 [VCP0] selected
Device: LG KG130
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" enabled
"keep calibration" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 3553110***xx024
current otp imei: 3553110***xx024
file saved: C:\Documents and Settings\gR\Desktop\eeprom_3553110***xx024_LG KG130_20080709-170952.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Alchemy data
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 576 sec
Remove/Install battery now !
Old 07-10-2008, 08:36   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
flash with latast version
Old 07-10-2008, 08:51   #3 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,900
hi
give me result ?
Old 07-10-2008, 08:51   #4 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
what was the purpose behind flashing was it dead or just for language changing ?
Old 07-10-2008, 08:53   #5 (permalink)
Member: 204684
Thanks Meter: 21
I only wanted to change lang as usualy. I flashed it with 10c and 10d version - no result
Old 07-10-2008, 10:13   #6 (permalink)
Member: 204684
Thanks Meter: 21
Infinity Support! Can you answer to me something? I must to know: shell I wait or buy new phone?
Old 07-10-2008, 10:26   #7 (permalink)
..::alexis::..'s Avatar
Member: 289200
Thanks Meter: 219
First of all try to write another code+alchemy.
If not help- backup original eeprom and write eeprom from support.
The Following User Says Thank You to ..::alexis::.. For This Useful Post:
Old 07-10-2008, 20:14   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
@gr_from
Any results after advice given by respected Mr. ..::alexis::.. ?
Old 07-12-2008, 08:59   #9 (permalink)
Member: 204684
Thanks Meter: 21
no results. same problem. with other boxes same situation. need 10f version but where can get this one?
Old 07-12-2008, 11:22   #10 (permalink)
Member: 204684
Thanks Meter: 21
...and I made this thread ONLY after I tryed ALL versions on support. only once on the screen apeared something normal. But the phone hang up and after that (no matter what I did) sreen is blue again. And than I had made this thread.
Old 07-12-2008, 11:39   #11 (permalink)
Member: 130995
Hello,
Did you tried to use repair_eeprom and repair_ffs files ?
Old 07-12-2008, 11:43   #12 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
Originally Posted by InfinitySupport View Post
Hello,
just a question for repair ffs files where to load it in eprom files icon or ffs icon because the extension .bin not included in ffs icon i use all files option in ffs icon to load ffs repair files
Old 07-12-2008, 12:07   #13 (permalink)
Member: 130995
Hello,
in fact it\'s not so important, you can use ffs files like eeprom files.
Old 07-13-2008, 08:05   #14 (permalink)
Member: 289200
Thanks Meter: 219
Maybe try to open phone and check what version must be in phone(label on flash IC)
Because for example C1100 have two different firmmwares type- 1xx and 2xx
And when you write 1xx to phone with 2xx you get working phone with blue screen.
Old 07-13-2008, 17:53   #15 (permalink)
Member: 204684
Thanks Meter: 21
I fought the same. But as I wrote before version was 10f. And I'll check label as you offered. The phone is new that's why I didn't want to open it.
I'll post results tommorow.
thanks
vodafone 226 blue light on sreen after flash hishamalrife FuriousGold 4 11-01-2008 15:25
X820 white sreen after flash borkoi Trident/AGERE Platform 9 05-19-2007 02:17
T610 Blue Screen after Flash !! Syed Sony Ericsson 17 05-07-2004 00:52
7210 blue screan after flash manijak Nokia Digital Core Technology 4 ( DCT-4 ) 8 03-23-2004 07:34
Panasonic GD93 with blue led after flashing... :( s.Mobi Panasonic 3 10-18-2002 06:36
Page generated in 0.21312 seconds with 9 queries
