05-21-2009, 10:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 983750 Status: Offline Thanks Meter: 26 | kg 110 imei repair module v1.36 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 354701012992322 current otp imei: 054701010000000 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354701012992322_LG-KG110_20050301-164541.B1E.bin ........ version: 404-XXV10j91KG110P40FL Check flash Done Check space ... current eeprom imei: 354701012992322 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 32 sec Remove/Install battery now ! infinity not repair imei of lg kg110 i tried many times log is posted here is dere i m doing wrong den plz tell me |
05-21-2009, 11:08 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Repair_imei_LG-KG110.txt |
05-27-2009, 20:14 | #5 (permalink) |
Freak Poster Join Date: Jan 2009 Location: warangal Age: 38
Member: 958436 Status: Offline Sonork: 100.1593478 Thanks Meter: 39 | hi go to Infinity support area dowland KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M this version file after flash to your poblem sovled |
The Following 3 Users Say Thank You to .::sravan::. For This Useful Post: |
05-27-2009, 20:41 | #6 (permalink) |
Member: 958436 Status: Offline Sonork: 100.1593478 Thanks Meter: 39 | my dear frind this is prcoser go to"Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked |
kg 110 imei problem 1000% solved | roshantelecom&s | Infinity-Box | 10 | 10-12-2010 22:40 |
Can not repair g kg 110 imei | himanshu taldar | Z3X-Team Products | 3 | 02-12-2009 06:45 |
lg kg 110 imei repair | bilal_mobile | Infinity-Box | 5 | 10-23-2008 15:45 |
KG-110 imei problem | Kashif Khan | Multi-Box | 2 | 06-06-2007 10:09 |
kg-110 imei ?2002000 | moie70 | Multi-Box | 0 | 06-05-2007 14:57 |
