10-13-2007, 07:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 368546 Status: Offline Thanks Meter: 235 | kg 110 imei problem 1000% solved alamgir |
10-14-2007, 17:41 | #3 (permalink) | |
If you really a professional but not a complete beginner w/o any experience and knowledges you should explain what is the problems that you have with Infinity-Box software, what was module name and version, what was the problem exactly, post here log etc. so we can see what is the problem and give you an advice where you was wrong and what you must do to get good results. Are you ready to make so ? | |
10-14-2007, 22:42 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | http:///vbb/showthread.php?t=452205 http:///vbb/showth...ighlight=kg110 this problem was 2 month old i done many pcs with fg but inifnity no work on kg110 http:///vbb/showth...ighlight=kg110 no response from infinity support Last edited by ahmertelecom; 10-14-2007 at 22:49. |
10-15-2007, 14:51 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @ahmerparacha http:///vbb/showpo...28&postcount=3 |
10-20-2007, 18:55 | #6 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | but 10 out of 9 says problem not solved its mean software bugs plz check and remove bugs not say send software logs trust your customers its say 100% corrrect |
10-20-2007, 20:02 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | of course here you see only messages with problems but not reports about well done job http:///vbb/showthread.php?t=456703 |
01-25-2009, 13:08 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | use files and instruction from support area: \flashfiles\LG\KG110\full_flash |
10-11-2010, 11:10 | #10 (permalink) |
Registered User Join Date: Jul 2009
Member: 1076639 Status: Offline Thanks Meter: 3 | frndz ihave a lg kg110 its imei starts with 70000 now problem is simcard reg failure i tried to over write its back panel imei after format the handset but now same problem remaining pls tell me anybody a good solution...... |
10-12-2010, 22:40 | #11 (permalink) | |
Please, see an instruction on your HDD: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\LG\Repair_imei_LG-KG110.txt | |
The Following 4 Users Say Thank You to InfinitySupport For This Useful Post: |
KG-110 imei change? | aminnovelty | Infinity-Box | 14 | 03-31-2009 06:51 |
Can not repair g kg 110 imei | himanshu taldar | Z3X-Team Products | 3 | 02-12-2009 06:45 |
lg kg 110 imei repair | bilal_mobile | Infinity-Box | 5 | 10-23-2008 15:45 |
KG-110 imei problem | Kashif Khan | Multi-Box | 2 | 06-06-2007 10:09 |
kg-110 imei ?2002000 | moie70 | Multi-Box | 0 | 06-05-2007 14:57 |
