05-27-2007, 13:45 | #1 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Belarus Age: 52
Member: 19585 Status: Offline Thanks Meter: 19 | Problem with Motofone F3 How repair? |
05-27-2007, 20:49 | #2 (permalink) | |
Freak Poster Join Date: Oct 2003 Location: TEMA
Member: 42981 Status: Offline Sonork: 1583521 Thanks Meter: 9 | Hi Quote:
05-27-2007, 21:01 | #3 (permalink) |
No Life Poster Join Date: Oct 2004 Location: gsmworld Age: 43
Member: 85537 Status: Offline Thanks Meter: 66 | To access the advanced settings, press * * * [number code] * [action] QUOTE Phone Setting Number Code Change Language 520 Select time format 470 Set Voicemail number 644 Voice Prompts ON | OFF (can also be toggled by pressing [action] on the volume menu) 510|511 Keypad tones ON | OFF 250|251 Auto keypad lock ON | OFF 260|261 Set SIM Pin 300 SIM Pin ON | OFF 310|311 Reset Factory settings 000 Restricted Calling (Phonebook only) ON | OFF 160|161 Prepaid Balance Display ON | OFF 500|501 Set Balance Inquiry Number to # * 642 The last two are only available if supported by the service provider. Additionally, you can display Phone information details by pressing: * * 9 9 9 9 * [action] Undocumented Codes - Use at your own risk! Switch something unkown ON | OFF 130|131 Switch something unkown ON | OFF 400|401 Display network currently receiving service from 480 Display list of networks within range 481 Show OK (?) 700 Enter a number, then text (CAUTION) 701 try this bro |
06-16-2007, 12:56 | #7 (permalink) |
Freak Poster Join Date: Feb 2006 Age: 43
Member: 232856 Status: Offline Thanks Meter: 69 | hi viking i try your methode but not work for me. can you explain more please, i have 200 pcs without ringtones ... thank's infinity team for FFS FORMAT button its just to delete fs ... |
06-16-2007, 14:17 | #9 (permalink) |
Member: 232856 Status: Offline Thanks Meter: 69 | tried on 5 phone 1 format ffs 2 full flash ( main and lng) 3 remove battery 4 power on 5 choice lng ( french for me ) 6 allow to voice 7 power off 8 power on 9 no ringtone but voice is ok in menu. need your help please |
06-22-2007, 13:29 | #11 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 368546 Status: Offline Thanks Meter: 235 | how to slove motofone F3 ringtones !!! -------------------------------------------------------------------------------- hi to all. ive searched how to slove ringtones probleme after "FFS FORMAT" and after many solution i found this one: 1: FFS format 2: Flash with this versions Moto-F3_Main_R3T621_G_15.18.12R.A8M and Moto-F3_LP_Flex_R3T621_G_15.18.12R_GSDTNGO000HG00165034 _En_Ar.A8P 3: power on with sim card choice lang 1 ( per ex ) set houre ect ... 4: do reset by ***000* and confime with up arrow ( just upside call button ) 5: POWER OFF with button, don't remove battery 6: power on and magic, ringtones work. now your phone work but if you don't want this language pack you can reflash your phone with any version you want ( firmware and language ) but NEVER USE FFS FORMAT... |
Unlock Motofone F3 | ruyramonn | Motorola ODM | 10 | 10-19-2007 10:10 |
Motofone F3 unlocking Possible? | dannybz | Motorola P2k | 5 | 06-14-2007 16:08 |
Motofone F3 | xavien | Motorola P2k | 1 | 02-15-2007 08:53 |
Motorola Motofone F3 | JoAoOpAuLo | Infinity-Box | 9 | 01-15-2007 22:27 |
motofone F3 locked | totalmanish | Infinity-Box | 0 | 12-24-2006 06:52 |
