Old 06-05-2008, 07:59   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Kg195 Still Restart????
I have got one KG195, Without sim card working ok but when i insert sime card then restart, i have format it with COMPLETE FORMAT, SAFE FORMAT, Then i have flash and repair eeprom then repair IMEI, then same condition.
KG195P64-ESA-V10e-***-XX_OCT-31-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D_En_Ml_Id_Vn_Th_Cn.B0M
COM4 selected
Device: LG-KG195
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:2E3C:9787
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D.BIN
ver. sw2: 7S7332AA00-001-R1D, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
flash: 98004900000002:C8D21000000000
Finalization Done
Finished, time used: 28 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 06-05-2008, 08:09   #2 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 658
try this code without sim card 2945#*# and choose format NVRAM it will be okey
also remove memory card then try
Z.K
Old 06-05-2008, 11:16   #3 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Your phone is restart automatically or it will restart after any key pressing.
Thankz.
Xtreme Mobile.
BRB.
POST ME THE REPLY.
Old 06-05-2008, 13:46   #4 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
bother try to format option (whole flash chip) and after flash your phone
Old 06-05-2008, 18:16   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@alamgarh
Did you tried to make energency/sos call without sim card ?
What is the results ?
Old 06-05-2008, 19:59   #6 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
COM4 selected
Device: LG-KG195
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
JUST DO UNLOCK N UR FONE BECOMES Okey,,,,,tried on KG288,,,,KG 270
Old 06-05-2008, 20:21   #7 (permalink)
maka_gsm's Avatar
Member: 309772
Thanks Meter: 31
Z.K
By using this code and then enter 6 it will be ok for you/
Old 06-06-2008, 05:57   #8 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
I have tried all methods and then post here, i have do whole chip format then flash it with new version, try 2945#*# try format nand, and many times it restart after signal comes, and some time it restart with pressing keys. i have repair its imei and do unlock but it show no lock.
Old 07-02-2008, 08:55   #9 (permalink)
Member: 230911
Thanks Meter: 177
I did all but all failed. I did all the possible steps after flashing but nothing. The LG logo comes and disapear
Old 07-02-2008, 14:23   #10 (permalink)
Member: 130995
Please, explain what was your "I did all" operations ?
Old 08-02-2008, 17:51   #11 (permalink)
Member: 86994
Sonork: 100.1584487
Thanks Meter: 124
light off result mobile off
i hav a problem with kg 195
when its lcd light goes off or when it goes in safe mode it shut down and restart i format it completely unlock it repair imei then flash it but no luck
so need a solution
Old 08-02-2008, 20:17   #12 (permalink)
Member: 130995
Can you power-on phone without sim-card ?
Old 08-18-2008, 16:39   #13 (permalink)
Member: 214340
Thanks Meter: 906
Dear Infinity Support with out sim card its not restarting when sim inserted it restarts???
Old 08-18-2008, 18:21   #14 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
try to dial 112 without sim card.and check if phone restarts or remains on
Old 08-19-2008, 16:15   #15 (permalink)
Member: 214340
Thanks Meter: 906
Dear Bro the code 2945#*# worked fine but it still have little problem it goes on searching some time wat could be the solution? thanx n BR
[D750i] still restarting with memory card kfiato Sony Ericsson 0 05-17-2006 15:39
N7710 Still restarting after flash With Ufs3..... MUNEEB_AKHTAR_RAZA UFS2 + UFS3-Tornadoflasher 7 04-22-2006 04:35
N7710 Still restarting after flash With P-Flasher..... MUNEEB_AKHTAR_RAZA powerflasher 4 03-20-2006 15:21
N7710 Still restarting after flash With Twiater..... MUNEEB_AKHTAR_RAZA Twisterflasher 0 03-08-2006 11:31
GX15 still restarting foony Sharp 2 06-29-2005 11:20
Page generated in 0.27453 seconds with 9 queries
