Kg195 Still Restart???? I have got one KG195, Without sim card working ok but when i insert sime card then restart, i have format it with COMPLETE FORMAT, SAFE FORMAT, Then i have flash and repair eeprom then repair IMEI, then same condition. KG195P64-ESA-V10e-***-XX_OCT-31-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D_En_Ml_Id_Vn_Th_Cn.B0M COM4 selected Device: LG-KG195 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:2E3C:9787 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D.BIN ver. sw2: 7S7332AA00-001-R1D, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000002:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:C8D21000000000 Finalization Done Finished, time used: 28 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
try this code without sim card 2945#*# and choose format NVRAM it will be okey also remove memory card then try Z.K |
Your phone is restart automatically or it will restart after any key pressing. Thankz. Xtreme Mobile. BRB. POST ME THE REPLY. |
bother try to format option (whole flash chip) and after flash your phone |
@alamgarh Did you tried to make energency/sos call without sim card ? What is the results ? |
JUST DO UNLOCK N UR FONE BECOMES Okey,,,,,tried on KG288,,,,KG 270 |
I have tried all methods and then post here, i have do whole chip format then flash it with new version, try 2945#*# try format nand, and many times it restart after signal comes, and some time it restart with pressing keys. i have repair its imei and do unlock but it show no lock. |
I did all but all failed. I did all the possible steps after flashing but nothing. The LG logo comes and disapear |
light off result mobile off i hav a problem with kg 195 when its lcd light goes off or when it goes in safe mode it shut down and restart i format it completely unlock it repair imei then flash it but no luck so need a solution |
Can you power-on phone without sim-card ? |
Dear Infinity Support with out sim card its not restarting when sim inserted it restarts??? |
