@mobile_hotman please, read this advice again: http:///vbb/showpo...3&postcount=14 |
If phone can not make 112 call in most cases it means that phone hardware is faulty, you must replace PA. |
You must check phone hardware very carefully. |
Lg kg195 sat on & restart |
@haji2all Please, little bit more information about your problem. |
only try to safe formate its ok100%%%%%%%%%%%%%%%%%%%% i ll do it use this method kg200 kg300 kg195 |
Sir my set goes off while dialing 112.... problem is restart when insert sim,,,,,with out sim it is okey,,,,BR |
Hello, If phone can not make 112 call in most cases it means that phone hardware is faulty, you must replace PA. |
Hello, Did you tried to flash and format phone ? |
flash with latest verson then flash its eeprom files then go to phone setting then go to display settings backlite time increase it to 40 to 50 seconds problem will be solved........ note:-- this is a hardware problem but also solved with software problem for just a time limit so plz dont use these sets for much time..... THanks best regards.......... |
