Old 09-28-2007, 10:05   #1 (permalink)
Member: 25763
Thanks Meter: 18
C139 : Phone Is Hacked
Hi All
I Have A Motorola C139 Handset Showing Phone Is Hacked. I Have Flashed With The Latest Firmware+flex+lp (ver. 1.3.29, ) & Eeprom Ver 13.39e. But The Problem Remains The Same. I Have Searched The Posts But The Only Method Posted Is Flash Firmware Pack , Which Is Not Helping.
Old 09-28-2007, 10:29   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
flash phone with 1.x.x firmware and make "unlock" procedure
Old 10-03-2007, 11:29   #3 (permalink)
Member: 25763
Thanks Meter: 18
Hi
I have tries flashing with different Main+LP+Flex (1.3.28 ver)..But Problem remains the same. Also when I try to flash the Repair EEPROM
it says "error: flash chip detection problem".Have checked the model no correctly and flASHED.
COM14 [VCP0] selected
Action: flash
Skip: Firmware
Skip: Language Pack
Skip: Flex
Write: Eeprom
Device: C139,C140
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 02
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
startup condition detected
SW version: 1.3.28
HW version: _E88
LP ver: LPL_C139_LATAM_Z1B
Flex ver: FFL_C139_3W_X1B
imei otp: 357251005406408
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_357251005406408_20071003-155354.31E.bin
imei eeprom: D596F35420ABA7F
Check Flash-2 Done
Write...
Writing: Eeprom
Write Done
Finished, time used: 14 sec
Remove/Install battery now !
Please post solution ..
Old 10-03-2007, 14:09   #4 (permalink)
Member: 130995
Flash phone with 1.0.x flash files set and make unlock
Old 12-22-2007, 18:32   #5 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
Simple, Phone Needs To Be Flashed Back To Version 1.
Old 05-07-2008, 13:11   #6 (permalink)
akash_hul's Avatar
Member: 716744
Thanks Meter: 85
soilve ur prob
flash with 1.0.3***
Old 05-07-2008, 13:49   #7 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Dear flash the phone with last uploaded version (Last upload by date)
U r problem will be solve.
Post result.
Old 06-24-2008, 08:49   #8 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
it done by restoring eeprom... work fine
j100i phone is hacked djpaul Infinity-Box 32 12-15-2009 18:44
C139 phone is hacked tavoonly Infinity-Box 18 10-23-2008 04:44
Motorola W208 : Phone is Hacked !!! ??? :::: FIXED DOWNLOAD LAST UPDATE :::: jamal2010 PolarBox 3 13 09-23-2008 11:52
motorola c139 phone is hacked..... rk19801 Infinity-Box 1 07-22-2007 09:07
C117 Phone is Hacked.. muksforu Infinity-Box 24 01-03-2007 12:11
Page generated in 0.16283 seconds with 9 queries
