Old 09-06-2008, 10:59   #1 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
pls halp infinity team
segamatel s1 is dade
Old 09-06-2008, 13:54   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Originally Posted by d.jain View Post
segamatel S1 Is Dade
What's Your Prob ? Post Your Ditels Log For Infinity.
Old 09-07-2008, 23:39   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Just flash and format your phone with Infinity-Box.
If phone still can't power on you must explain what is phone history so detailed as possible.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-16-2008, 08:57   #4 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
he is phone history -----COM4 [VCP0] selected
Checking data, wait...
Connect...
Press Power button now !
Connect Ok
Boot...
Boot Ok
Set baud...
921600
Set baud Ok
Read info...
flash: BF7353FFFF0052:00008500000000
flash: SST SST34HF3244/3284 U 4Mb
Read info Ok
Check flash...
Check flash Ok
Check space...
Check space Ok
Write...
Area: File System
Write: File System
error: no any expected answer
error: flash write error: 0230A000:00002000
error: wrong answer: C3
00E0E000E0E000E0E0E0E00000869886988698869806801880 1E8060806680
Write failed
Finished, remove/install battery now !
Time used: 42 sec halppppppppppppp Infinity support blue--245x log
Old 10-16-2008, 08:57   #5 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
Old 10-17-2008, 16:35   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what box do you use as interface (cable) ?
pls help infinity team... pls @@@___@@@ Infinity-Box 22 03-19-2010 19:48
pls help infinity team crackp0d Infinity-Box 6 01-11-2009 07:31
pls help infinity team lg ke 970 R@jusat Infinity-Box 6 12-01-2008 12:58
S81 unlock pls help infinity team ringtone MD S-Gold Based Phones 0 09-04-2008 10:02
cect S500 pin out. pls help infinity team HEDEF_GSM Infinity-Box 1 06-20-2007 11:55
Page generated in 0.14739 seconds with 9 queries
