04-13-2009, 13:35 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Lg kp100 unlock done":;thanks infinty;:" COM4 [VCP0] selected module v1.60 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL KP100 VODAFONE ES 01 FL 34 V10a 214-01 NOV-06-2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090412-235805.B1E.bin loading data... data loaded imei: 35847902867717100 reading eeprom-security_35847902867717100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35847902867717100_20090412-235806.B1E.bin reading eeprom-complete_35847902867717100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35847902867717100_20090412-235812.B1E.bin backup critical area Done Check memory ... loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... data loaded code: 28004227 error: not locked or unknown eeprom Check memory Failed Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
LG KP100 Unlock | h4mza | LG | 8 | 07-03-2011 01:51 |
Lg KP100 unlocked sucessfull by n-box | randr | LG | 0 | 09-13-2008 09:59 |
lg kp100 unlock | newerno | Infinity-Box | 10 | 09-12-2008 09:26 |
LG KP100 unlock problem | msashami | Infinity-Box | 1 | 09-02-2008 12:04 |
LG KP100 Unlock OK | Amir-SkillZ | Infinity-Box | 0 | 08-12-2008 08:21 |
